| » LG washer IE error code |
Model Number: WM1814CW Brand: -other- Age: 5 - 10 years
My LG washer is showing an IE error code. The cycle will start as normal but when it gets down to either 32 or 34 minutes, the timer stops advancing and so the unit shuts down and displays this code. I am not sure if it is the PCB assembly or the main circuit board that needs to be replaced.
Multiple attempts top reset the unit with the plug pulled and the on button depressed have not cleared the issue/fault. Any suggestions or experience with this would be greatly appreciated. Thank you. Ads By Google Related Models |
Hello. The IE failure code is an inlet valve problem,
Part number: AP4442608 Model WM1814CW Thank you and good luck !
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
| LG Washer Error Code tE | ccq | Washer Repair | 1 | 03-19-2012 07:51 PM |
| Washer error code F 51 | anmika | Washer Repair | 1 | 11-02-2011 07:18 PM |
| LG Washer LE error code | dheusser | Washer Repair | 1 | 04-14-2011 09:27 AM |
| LE error code on lg washer | jrogers297 | Washer Repair | 0 | 12-02-2010 04:05 AM |
| Error code E38 washer | things4u2 | Washer Repair | 1 | 09-20-2010 05:23 AM |
