Discuss
washer show ob on display and won't drain
 in
Washer Repair
i recently change the u-joint kit on it, but now shows on display ob that code is for off
Appliance Repair Forum > Appliance Repair Help > Washer Repair » washer show ob on display and won't drain
  #1 (permalink)
Old 01-15-2008, 06:10 AM
jaime jaime is offline
Junior Member
jaime is on a distinguished road
Default washer show ob on display and won't drain
Model Number: 11022062101   Brand: Kenmore   Age: 1 - 5 years
i recently change the u-joint kit on it, but now shows on display ob that code is for off balance i redistribute the load i even took the load out but keep shows the same ob another thing the machine is not draining out if you can help me with same advice here i would aprecciated
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-15-2008, 05:53 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Most likely the problem is a clogged or broken drain pump.
There is a good possibilities that replacing the drain pump will fix an off balance problem too.
- The part number for the drain pump is AP3776224
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 01-21-2008, 06:25 PM
Junior Member
Default
Ok... i just got the drain pump delivered, i put it on ; and everything is working perfectly thanks for your help.
  #4 (permalink)
Old 01-22-2008, 04:04 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
I'm glad you were able to fix it.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Calypso Washer Washer Won't Drain SamB Washer Repair 3 11-27-2007 02:41 PM
Washer won't drain jmcdonald62 Washer Repair 0 11-20-2007 08:19 AM
My washer will not drain lisalisajoey Washer Repair 1 10-09-2007 03:04 AM
washer won't drain jmsnewton Washer Repair 5 09-04-2007 11:45 PM
Countdown Display INOP, Washer cycles normally Julia Dishwasher Repair 0 08-20-2007 10:03 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
