Discuss
Whirlpool washer will agitate and drain, but won't spin unless open/close lid
 in
Washer Repair
My whirlpool washer model LSQ9645KQ0 will agitate fine. When it changes cycles and is supposed to drain and spin, it
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Whirlpool washer will agitate and drain, but won't spin unless open/close lid
  #1 (permalink)
Old 03-19-2012, 03:41 PM
Junior Member
bnavarre is on a distinguished road
Default Whirlpool washer will agitate and drain, but won't spin unless open/close lid
Model Number: LSQ9645KQ0   Brand: Whirlpool   Age: 5 - 10 years
My whirlpool washer model LSQ9645KQ0 will agitate fine. When it changes cycles and is supposed to drain and spin, it only drains. In order for me to get it to spin, I have to raise the lid and re-close it. I have ruled out the switch because I disconnected it from the control panel and installed a temporary jumper in that connection (permanently closed lid condition). Even in this situation, I had to remove the jumper and re-install for it to begin spinning. Could this simply be the clutch?
Ads By Google
Related Models
Whirlpool LSQ9645KQ0 WASHER
Whirlpool LSQ9645KQ1 WASHER
Whirlpool LSQ9645KT0 WASHER
Whirlpool LSQ9645KT1 WASHER
Whirlpool LSQ9650PG0 AUTOMATIC WASHER
Whirlpool LSQ9650PG1 AUTOMATIC WASHER
Whirlpool LSQ9650PG2 AUTOMATIC WASHER
Whirlpool LSQ9650PG3 AUTOMATIC WASHER
Whirlpool LSQ9650PG4 AUTOMATIC WASHER
Whirlpool LSQ9650PW0 AUTOMATIC WASHER
Whirlpool LSQ9650PW1 AUTOMATIC WASHER
Whirlpool LSQ9650PW2 AUTOMATIC WASHER
Whirlpool LSQ9650PW3 AUTOMATIC WASHER
Whirlpool LSQ9650PW4 AUTOMATIC WASHER
Whirlpool LSQ9659LG0 WASHER - DIRECT DRIVE
Whirlpool LSQ9659LG1 AUTOMATIC WASHER
Whirlpool LSQ9659LW0 WASHER - DIRECT DRIVE
Whirlpool LSQ9659LW1 AUTOMATIC WASHER
Whirlpool LSQ9659PG0 AUTOMATIC WASHER
Whirlpool LSQ9659PG1 AUTOMATIC WASHER
Whirlpool LSQ9659PG2 AUTOMATIC WASHER
Whirlpool LSQ9659PG3 AUTOMATIC WASHER
Whirlpool LSQ9659PG4 AUTOMATIC WASHER
Whirlpool LSQ9659PW0 AUTOMATIC WASHER
Whirlpool LSQ9659PW1 AUTOMATIC WASHER
Whirlpool LSQ9659PW2 AUTOMATIC WASHER
Whirlpool LSQ9659PW3 AUTOMATIC WASHER
Whirlpool LSQ9659PW4 AUTOMATIC WASHER
Whirlpool LSQ9660PG0 AUTOMATIC WASHER
Whirlpool LSQ9660PG1 AUTOMATIC WASHER
Whirlpool LSQ9660PG2 AUTOMATIC WASHER
Whirlpool LSQ9660PG3 AUTOMATIC WASHER
Whirlpool LSQ9660PG4 AUTOMATIC WASHER
Whirlpool LSQ9660PW0 AUTOMATIC WASHER
Whirlpool LSQ9660PW1 AUTOMATIC WASHER
Whirlpool LSQ9660PW2 AUTOMATIC WASHER
Whirlpool LSQ9660PW3 AUTOMATIC WASHER
Whirlpool LSQ9660PW4 AUTOMATIC WASHER
Whirlpool LSQ9665JQ0 WASHER
Whirlpool LSQ9665JQ1 WASHER
Whirlpool LSQ9665JQ2 WASHER
Whirlpool LSQ9665JQ3 WASHER
Whirlpool LSQ9665JQ4 WASHER
Whirlpool LSQ9665JT0 WASHER
Whirlpool LSQ9665JT1 WASHER
Whirlpool LSQ9665JT2 WASHER
Whirlpool LSQ9665JT3 WASHER
Whirlpool LSQ9665JT4 WASHER
Whirlpool LSR4100HQ0 AUTOMATIC WASHER
Whirlpool LSR4311DQ0 WASHER
Whirlpool LSR5100HQ0 AUTOMATIC WASHER
Whirlpool LSR5100KQ0 RESIDENTIAL WASHER
Whirlpool LSR5100LQ0 WASHER - DIRECT DRIVE
Whirlpool LSR5101LQ0 WASHER - DIRECT DRIVE
Whirlpool LSR5101LQ1 AUTOMATIC WASHER
Whirlpool LSR5102LQ1 AUTOMATIC WASHER
Whirlpool LSR5121HQ0 AUTOMATIC WASHER
Whirlpool LSR5121JQ0 AUTOMATIC WASHER,
Whirlpool LSR5132AG0 DIRECT-DRIVE WASHER
Whirlpool LSR5132AN0 DIRECT-DRIVE WASHER
Whirlpool LSR5132AW0 DIRECT-DRIVE WASHER
Whirlpool LSR5132HQ0 AUTOMATIC WASHER
Whirlpool LSR5132HQ1 AUTOMATIC WASHER
Whirlpool LSR5132JQ0 COMPACT WASHER
Whirlpool LSR5132JQ1 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSR5132JQ2 WASHER - DIRECT DRIVE
Whirlpool LSR5132PQ0 AUTOMATIC WASHER
Whirlpool LSR5132PQ1 AUTOMATIC WASHER
Whirlpool LSR5132PQ3 AUTOMATIC WASHER
Whirlpool LSR5132PQ4 AUTOMATIC WASHER
Whirlpool LSR5232DW0 AUTOMATIC WASHER
Whirlpool LSR5232LQ0 WASHER - DIRECT DRIVE
Whirlpool LSR5232LQ1 AUTOMATIC WASHER
Whirlpool LSR5233AG0
Whirlpool LSR5233AN0
Whirlpool LSR5233AW0 Washers*
Whirlpool LSR5233EQ0 AUTOMATIC WASHER
Whirlpool LSR5233EQ1 DIRECT-DRIVE WASHER
Whirlpool LSR5233EQ2 DIRECT-DRIVE HOME WASHERS
Whirlpool LSR6132BN0 DIRECT-DRIVE WASHER
Whirlpool LSR6132BW0 DIRECT-DRIVE WASHER
Whirlpool LSR6132BW1 AUTOMATIC WASHER
Whirlpool LSR6132DQ0 DIRECT-DRIVE HOME WASHERS
Whirlpool LSR6132DZ0 DIRECT-DRIVE HOME WASHERS
Whirlpool LSR6132EQ0 AUTOMATIC WASHER
Whirlpool LSR6132EQ1 AUTOMATIC WASHER
Whirlpool LSR6132EZ0 AUTOMATIC WASHER
Whirlpool LSR6132EZ1 AUTOMATIC WASHER
Whirlpool LSR6132HQ0 AUTOMATIC WASHER
Whirlpool LSR6132HQ1 AUTOMATIC WASHER
Whirlpool LSR6132HZ0 AUTOMATIC WASHER
Whirlpool LSR6232JQ0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSR6232JQ1 WASHER - DIRECT DRIVE
Whirlpool LSR6232JQ2 AUTOMATIC WASHER
Whirlpool LSR6233BG0 AUTOMATIC WASHER
Whirlpool LSR6233BN0 AUTOMATIC WASHER
Whirlpool LSR6233BN1 WASHER
Whirlpool LSR6233BW0 AUTOMATIC WASHER
Whirlpool LSR6233BW1 WASHER
Whirlpool LSR6233DN0 AUTOMATIC WASHER
Whirlpool LSR6233DW0 AUTOMATIC WASHER
Whirlpool LSR6244AW0 Washers*
Whirlpool LSR6332KQ0 WASHER
Whirlpool LSR6332KQ1 AUTOMATIC WASHER
Whirlpool LSR6334LQ0 WASHER - DIRECT DRIVE
Whirlpool LSR6334LQ1 AUTOMATIC WASHER
Whirlpool LSR6335LQ0 WASHER - DIRECT DRIVE
Whirlpool LSR7010PQ0 AUTOMATIC WASHER
Whirlpool LSR7010PQ1 AUTOMATIC WASHER
Whirlpool LSR7010PQ2 AUTOMATIC WASHER
Whirlpool LSR7133KQ0 WASHER
Whirlpool LSR7133KQ1 AUTOMATIC WASHER
Whirlpool LSR7133PQ0 AUTOMATIC WASHER
Whirlpool LSR7133PQ1 AUTOMATIC WASHER
Whirlpool LSR7133PQ2 AUTOMATIC WASHER
Whirlpool LSR7200EQ0 AUTOMATIC WASHER
Whirlpool LSR7200EZ0 AUTOMATIC WASHER
Whirlpool LSR7233BG0
Whirlpool LSR7233BG1
Whirlpool LSR7233BG2
  #2 (permalink)
Old 03-19-2012, 03:58 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hello.
Most likely the problem is bad lid switch. It's basically works as a safety switch. When you put the lid down the switch actuates. To replace it you will have to remove the cabinet.
Look at the attached diagram#8 part#11.
The lid switch Part number: AP3100003
The breakdown diagrams and Replacement parts for Whirlpool LSQ9645KQ0 WASHER | AppliancePartsPros.com
Post the results. Thank you.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 03-19-2012, 04:54 PM
Junior Member
Default
I'm not convinced it's the switch. I disconnected the switch and installed a jumper in the connector at the control panel. The attached photo shows the jumper installed in the control panel side of the lid switch connector. In order to get the washer to spin, I had to remove the jumper and re-install. When re-installing the jumper, the washer began spinning immediately. Any other suggestions?
  #4 (permalink)
Old 03-20-2012, 09:36 AM
Expert
Default
Hello.
You are right. The problem is not the switch. In your case it's the timer.
Here why - Your washer has a neutral drain transmission. That means - the washer drains first then pausing for a few seconds
allowing the spin gears to engage, and only then the spin starts.
The timer is not pausing which makes the washer drain constantly. When you open and close the lid manually you imitating the pause.
The timer Part number: AP3020510
Thank you.
Please post the results.
__________________
  #5 (permalink)
Old 03-21-2012, 05:31 AM
Junior Member
Default
Thanks for the info. I may try the new timer.
I did some more investigation last night. What I found isn't much different than you say. When I heard the washer begin draining, I slowly lifted the lid. When I did, I noticed that upon the lid switch releasing and the draining operation stopping, the spin engaged slightly. Then, when closing the lid again, the drain and spin both worked. It appeared that lifting the lid either "reset" the timer as you say or it caused the spinning cycle to engage.
Does this change your opinion of it being the timer? I hate to spend the money on a new timer if it is not the right fix.
  #6 (permalink)
Old 03-21-2012, 10:12 AM
Expert
Default
Hi.
I'll stick with the timer.
You can return any unused parts, even if they has been installed.
Post the results.
__________________
  #7 (permalink)
Old 03-24-2012, 06:40 PM
Junior Member
Default
I have replaced the timer and have run one cycle successfully. It appears the original timer went bad after 10 years. I'll post again if this replacement doesn't solve the problem long term. Thanks for the assistance and advice.
  #8 (permalink)
Old 03-26-2012, 10:19 AM
Expert
Default
You are welcome.
__________________
  #9 (permalink)
Old 03-31-2012, 12:11 PM
Junior Member
Default
After further review, apparently changing the timer did not solve the problem. Maybe it was a coincidence that it worked the first time after changing the timer, but since then it has not worked properly. It is still doing the same thing. It will drain, but not spin. If you lift the lid while it is draining, the washer stops and at the last second the "spin" engages and turns about 1/2 a turn. Then, upon closing the lid, it spins as normal.
What's next?
  #10 (permalink)
Old 04-02-2012, 03:42 PM
Expert
Default
Hi.
For how long the washer is draining before you open the lid?
Simon.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool washer won't spin, drain, or agitate mosierap Washer Repair 8 12-15-2011 05:35 PM
washer wont spin unless i open then close lid idrinkalone Washer Repair 3 08-22-2011 01:57 AM
whirlpool washer will agitate, but wont spin or drain robert garbacz Washer Repair 5 04-11-2011 07:26 AM
Whirlpool Washer no drain, spin or agitate dstarnik Washer Repair 3 01-30-2011 05:33 AM
Maytag Washing won't spin & drain unless open & close lid hull98 Washer Repair 1 09-19-2009 04:15 PM
