| » Maytag frontloader controls locked |
Model Number: MFW9600SQ1 Brand: Maytag Age: 1 - 5 years
controls are locked, can anyone advise a solution?
If you have not already tried these,
1. Unplug the machine to see if the controls will free up 2. Check the drain system for any blockage or problems. If you can get the machine into diagnostic mode you may be able to determine the problem. Here is the tech sheet. http://www.servicematters.com/maytag...cs/8182208.pdf If you cannot get the machine into test mode, a new control board is likely needed, but if you replace it you are doing it on speculation since that cannot be confirmed as the problem. Wish I could be more definitive. Good luck.
__________________
"On certain Maytag models equipped with an electrical panel, the "controls locked" status light may be lit. If so, press and hold the cycle signal button for three seconds. This will turn off the controls locked feature, resetting the dryer for use."
| Display Modes | |
| Locked but unresponsive Maytag | dgmsam | Dishwasher Repair | 1 | 02-21-2009 06:05 AM |
| Maytag Oven clock and controls intermittently working | wildbio1 | Oven Repair (including Ranges and Cooktops) | 1 | 01-29-2009 10:09 AM |
| Dim Lights in controls of Maytag double oven range | cityfolks | Oven Repair (including Ranges and Cooktops) | 1 | 12-22-2008 02:48 PM |
| Ack! Maytag Stackable Frontloader | pnwpugmom | Washer Repair | 2 | 06-30-2008 12:59 PM |
| Controls locked light will not deactivate. | Dan Hogan | Dishwasher Repair | 0 | 03-31-2008 12:03 PM |
