Washer stopped before rinse/spin cyle with door locked. Now won't start at all.
Ran diagnostic stops immediately and locks door rinse/spin flashes
Replaced door switch because pin 1 and 3 resistance was 125 ohms on DL2 (manual says it should be 60). Pins 2 and 3 are 62 ohms which agrees with manual. New part showed up also had 125 ohms. Not surprising it didn't fix problem.
Replaced CCU unit. No difference.
Any suggestions appreciated.
Kenny
Hi Kenny
I would test the door switch for continuity ( it should show continuity when closed, non-continuity when open) at DS2 on the board and test the wiring between the CCU and the door lock assembly for continuity.
If this checks out, and it probably will, I am thinking the door lock assembly you received was defective since you are not getting the correct readings, and I would see if the selling firm will exchange under a warranty claim.
These Duet Sport's are great when they work but when they do not they are just awful to diagnose as you can see.
Good luck.
