My washer will wash, rinse and agitate. But when it comes to the spin cycle it will not spin. I have changed the drive block and still nothing. It does drain the water just no spinning to get excess water out. What else could be the problem? Any clues?
The typical diagnosis here is the the clutch. Try changing it out and see if that fixes your problem.
