| » Frigidare Washer Thumping Noise |
Model Number: 530SD0 Brand: Frigidaire Age: 5 - 10 years
Washer has started to make a thumping noise as it goes into spin the last few days. Will make the noise while starting to spin slowly then stops and reverses it self. After several cycles of this it will go into high speed spin. I can see the tub wobbling when it first starts the spin and that is when it makes noise. Suspect a spring has broken.
Hello . It sounds like you have a bad bearing , we will need the correct model # in order to give you the correct part #'s please check that and get back to us, the model # is located under the lid next to the hinge on a top loader, and on a front loader just open the door and it should be on the left hand side again by a hinge, thank you !
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
| Washer makes loud thumping noise! | Rigdawg58 | Washer Repair | 9 | 01-11-2012 03:01 AM |
| washer makes thumping noise at end of spin cycle | stlcpd3765 | Washer Repair | 1 | 08-25-2010 08:16 AM |
| washer making a thumping/banging noise | hoffmase | Washer Repair | 0 | 05-12-2010 05:34 PM |
| Washer making thumping noise on spin | Albo | Washer Repair | 2 | 01-20-2010 02:03 PM |
| Washer won't spin and makes thumping noise | Melissa Knutson | Washer Repair | 1 | 08-31-2009 12:36 PM |
