Discuss
Washer will fill,agitate,drain,But no spin
 in
Washer Repair
Washer will fill, agitate, then drains without spin. then fills up on rinse cycle agitate,drains,but no spin out, then nothing
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer will fill,agitate,drain,But no spin
  #1 (permalink)
Old 03-17-2012, 03:49 PM
Member
buddha131 is on a distinguished road
Default Washer will fill,agitate,drain,But no spin
Model Number: 11029522800   Brand: Kenmore   Age: 1 - 5 years
Washer will fill, agitate, then drains without spin. then fills up on rinse cycle agitate,drains,but no spin out, then nothing on spin cycle? Just a Buzzing motor. Do I have bad Transmission or timer or wiring?
Related Models
Kenmore 11029522800 RESIDENTIAL WASHER
Kenmore 11029522801 RESIDENTIAL WASHER
Kenmore 11029532800 RESIDENTIAL WASHER
Kenmore 11029532801 RESIDENTIAL WASHER
Kenmore 11029592800 RESIDENTIAL WASHER
Kenmore 11029592801 RESIDENTIAL WASHER
Kenmore 11029622800 RESIDENTIAL WASHER
Kenmore 11029622801 RESIDENTIAL WASHER
Kenmore 11029632800 RESIDENTIAL WASHER
Kenmore 11029632801 RESIDENTIAL WASHER
Kenmore 11029672800 RESIDENTIAL WASHER
Kenmore 11029672801 RESIDENTIAL WASHER
Kenmore 11029682800 RESIDENTIAL WASHER
Kenmore 11029682801 RESIDENTIAL WASHER
Kenmore 11029692800 RESIDENTIAL WASHER
Kenmore 11029692801 RESIDENTIAL WASHER
Kenmore 1102970093 COMPACT AUTOMATIC WASHER
Kenmore 11029722800 RESIDENTIAL WASHER
Kenmore 11029722801 RESIDENTIAL WASHER
Kenmore 11029727800 RESIDENTIAL WASHER
Kenmore 11029727801 RESIDENTIAL WASHER
Kenmore 11029732800 WASHER
Kenmore 11029732801 RESIDENTIAL WASHER
Kenmore 11029737800 WASHER
Kenmore 11029737801 RESIDENTIAL WASHER
Kenmore 11029802890 AUTOMATIC WASHER
Kenmore 11029812890 AUTOMATIC WASHER
Kenmore 11029812891 AUTOMATIC WASHER
Kenmore 11029822800 WASHER
Kenmore 11029822801 RESIDENTIAL WASHER
Kenmore 11029832800 WASHER
Kenmore 11029832801 RESIDENTIAL WASHER
Kenmore 11029842990 WASHER
Kenmore 11029842991 AUTOMATIC WASHER
Kenmore 11029852990 AUTOMATIC WASHER-GALAXY
Kenmore 11029852991 AUTOMATIC WASHER
Kenmore 11029852992 AUTOMATIC WASHER
Kenmore 11029882890 AUTOMATIC WASHER
Kenmore 11029882891 AUTOMATIC WASHER
Kenmore 11029884890 AUTOMATIC WASHER
Kenmore 11029884891 AUTOMATIC WASHER
Kenmore 11029892990 AUTOMATIC WASHER-TECH SHEET
Kenmore 11029894990 AUTOMATIC WASHER-TECH SHEET
Kenmore 11029962890 AUTOMATIC WASHER
Kenmore 11029962891 AUTOMATIC WASHER
Kenmore 1103348565 GEARCASE
Kenmore 110357116 GEARCASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110357177 GEARCASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110357970 BASKET DRIVE AND BRAKE ASM
Kenmore 110357972 GEAR CASE AND SUPERSTRUCTURE
Kenmore 110358364 BASKET DRIVE AND BRAKE ASM
Kenmore 110358365 GEAR CASE AND SUPERSTRUCTURE
Kenmore 110358371 GEARCASE AND SUPERSTRUCTURE
Kenmore 110358483 GEARCASE ASM
Kenmore 110358484 GEARCASE AND SUPERSTRUCTURE
Kenmore 110358485 GEARCASE AND SUPERSTRUCTURE
Kenmore 110358487 GEARCASE AND SUPERSTRUCTURE
Kenmore 110358507 GEAR CASE AND SUPERSTRUCTURE
Kenmore 110358795 GEAR CASE AND SUPERSTRUCTURE
Kenmore 110358841 GEARCASE AND SUPERSTRUCTURE
Kenmore 110359175 BASKET DRIVE & BRAKE ASM
Kenmore 110359178 GEAR CASE AND SUPERSTRUCTURE
Kenmore 110359279 GEARCASE PARTS
Kenmore 110359517 BASKET DRIVE AND BRAKE PARTS
Kenmore 110359699 BASKET DRIVE AND BRAKE PARTS
Kenmore 110360093 AMERICAN STANDARD MIXING VALVE ASSEMBLY
Kenmore 110360867 DOLE MIXING VALVE ASSEMBLY
Kenmore 110360868 AMERICAN STANDARD MIXING VALVE ASSEMBLY
Kenmore 110362101 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110362901 GEARCASE ASM
Kenmore 110363000 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110363082 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110364443 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110364444 BASKET DRIVE AND BRAKE PARTS
Kenmore 110364446 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110364494 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110365011 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110365012 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110365014 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110365359 GEARCASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110365712 GEARCASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110365859 GEARCASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110366660 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110366990 BASKET DRIVE & BRAKE ASM
Kenmore 110367551 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110367593 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 1103733107 KENMORE PORTABLE AUTOMATIC WASHER
Kenmore 110389246 GEARCASE PARTS
Briggs & Stratton 110402-0180-E1 ENGINE
Kenmore 11042182200 AUTOMATIC WASHER
Kenmore 11042182201 AUTOMATIC WASHER
Kenmore 11042722200 AUTOMATIC WASHER
Kenmore 11042722201 AUTOMATIC WASHER
Kenmore 11042822200 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11042822201 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11042822202 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11042822203 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11042824200 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11042824201 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11042824202 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11042824203 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11042826200 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11042826201 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11042832200 AUTOMATIC WASHER W/HORIZONTAL AXIS
Kenmore 11042832201 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11042834200 AUTOMATIC WASHER W/HORIZONTAL AXIS
Kenmore 11042834201 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11042836200 AUTOMATIC WASHER W/HORIZONTAL AXIS
Kenmore 11042836201 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11042922200 WASHER
Kenmore 11042922201 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11042922202 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11042922203 RESIDENTIAL WASHER
Kenmore 11042924200 WASHER
Kenmore 11042924201 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11042924202 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11042924203 RESIDENTIAL WASHER
Kenmore 11042926200 WASHER
Kenmore 11042926201 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11042926202 AUTOMATIC WASHER HORIZONTAL AXIS
  #2 (permalink)
Old 03-17-2012, 06:31 PM
ApplianceJunk's Avatar
Senior Expert
APP Volunteer
ApplianceJunk is on a distinguished road
Default
Could be a bad timer, motor or connection between the two on the wire harness.
Could also be something caught between the basket and outer tub that is keeping the basket from spinning.
__________________
ApplianceJunk.com ~ DIY Appliance Repair Forum
  #3 (permalink)
Old 03-19-2012, 01:09 PM
Member
Default
Hello, Put on spin to drain washer with some clothes in it, It worked!!! Seems to have problem after rinse cycle.After close look I noticed a burn mark on wire harness at motor from timer (blue wire).Can I replace wire or need new harness.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE washer will fill and drain but no spin/agitate corndogg Washer Repair 129 02-02-2015 06:28 AM
Washer will fill, drain, spin but won't agitate tmatsick Washer Repair 8 05-11-2011 03:05 PM
Washer won't spin/drain but it will fill and agitate Bethxrichy Washer Repair 1 04-11-2011 09:59 AM
Washer will fill & agitate, won't spin or drain legomom0701 Washer Repair 2 06-21-2010 11:11 AM
Washer will fill and agitate but not spin/drain at all Narapni Washer Repair 0 11-03-2007 01:20 AM
