| » which part do I need for water level control so washer does not over fill? |
Model Number: LSQ8243HQ0 Brand: Whirlpool Age: 5 - 10 years
Water fills beyond set level and will over fill not letting the wash cycle
start. Manually moving timer control to spin cycle will empty wash tub. Which part should be installed? Thank You, Paul Bailey PoolTime@tampabay.rr.com Ads By Google Related Models |
If you have to cut the water off to stop the water flow the water inlet valve is bad and needs replacing. If turning the washer off stops the water flow there is something wrong with the water level control such as the tube that runs from the water level control is stopped up or has came loose or the water level switch is bad. Washer Repair Guide
applianceman,
After turning the washer off the water flow did stop. I replaced the tube that runs from the water level control down to the tub and it resolved the problem. A really simple fix. Thank You for your time and help! Sincerely, Paul Bailey |
| Display Modes | |
| timer control or water level control? | Elehairyjob5 | Washer Repair | 3 | 02-18-2010 01:44 PM |
| Where is the water fill level screw | mellawilk | Refrigerator & Freezer Repair | 0 | 09-12-2009 02:35 PM |
| fill level on Maytag washer | tealle | Washer Repair | 1 | 08-18-2009 05:19 PM |
| water fill level overfills | tealle | Washer Repair | 2 | 08-17-2009 12:27 PM |
| water level control | johnnybnice | Washer Repair | 5 | 05-15-2009 02:30 AM |
