AppliancePartsPros.com
Appliance Repair Help
Washer Repair
GE Washer - Burning smell, sometimes won't spin
Washer has a burning smell after it runs a load. Sometimes it makes a loud humming noice after it has drained, but it won't spin. That doesn't happen all the time though, but the burning smell does happen everytime I run it.
Any suggestions on what it might be?
I bought this washer new 5 years ago.
Thanks!
Hello. You more than likely have something stuck in the pump, or the pump is going bad, I would remove it and check to see if it is clogged. Thank you Part number: AP3160348
Washer Repair
