Discuss
washer wont go throgh cycle
 in
Washer Repair
I have a front loader washer. when you close the door, select cycle, and push start, nothing happens. the red
Appliance Repair Forum > Appliance Repair Help > Washer Repair » washer wont go throgh cycle
  #1 (permalink)
Old 03-16-2012, 09:26 AM
jns jns is offline
Junior Member
jns is on a distinguished road
Default washer wont go throgh cycle
Model Number: 11042932200   Brand: Kenmore   Age: 5 - 10 years
I have a front loader washer. when you close the door, select cycle, and push start, nothing happens. the red cycle led just blinks. i checked for power to the door switch and get 19 volts at both pink wire terminals. my question is, how many volts should be present at the switch and is the problem the interface, control unit, or door switch?
thanks jeff
Ads By Google
Related Models
Kenmore 11042932200 WASHER
Kenmore 11042934200 WASHER
Kenmore 11042936200 WASHER
Kenmore 11043902201 WASHER
Kenmore 11043902202 WASHER
Kenmore 11043902203 WASHER
Kenmore 11044182400 COMPACT WASHER
Kenmore 11044182401 WASHER
Kenmore 11044722400 COMPACT WASHER
Kenmore 11044722401 RESIDENTIAL WASHER
Kenmore 11044826300 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11044826301 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11044832200 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11044832201 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11044832202 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11044834200 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11044834201 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11044834202 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11044836200 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11044836300 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11044836301 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11044921300 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11044921301 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11044921302 RESIDENTIAL WASHER
Kenmore 11044931300 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11044931301 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11044931302 RESIDENTIAL WASHER
Kenmore 11044932200 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11044932201 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11044932202 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11044932203 RESIDENTIAL WASHER
Kenmore 11044934200 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11044934201 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11044934202 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11044934203 RESIDENTIAL WASHER
Kenmore 11044936200 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11044936201 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11044936202 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11044936203 RESIDENTIAL WASHER
Kenmore 11045081400 RESIDENTIAL WASHER
Kenmore 11045081401 RESIDENTIAL WASHER
Kenmore 11045081402 RESIDENTIAL WASHER
Kenmore 11045081403 RESIDENTIAL WASHER
Kenmore 11045081404 RESIDENTIAL WASHER
Kenmore 11045087400 WASHER
Kenmore 11045087401 RESIDENTIAL WASHER
Kenmore 11045087402 RESIDENTIAL WASHER
Kenmore 11045087403 RESIDENTIAL WASHER
Kenmore 11045087404 RESIDENTIAL WASHER
Kenmore 11045088400 WASHER
Kenmore 11045088401 RESIDENTIAL WASHER
Kenmore 11045088402 RESIDENTIAL WASHER
Kenmore 11045088403 RESIDENTIAL WASHER
Kenmore 11045088404 RESIDENTIAL WASHER
Kenmore 11045089400 WASHER
Kenmore 11045089401 RESIDENTIAL WASHER
Kenmore 11045089402 RESIDENTIAL WASHER
Kenmore 11045089403 RESIDENTIAL WASHER
Kenmore 11045089404 RESIDENTIAL WASHER
Kenmore 11045091400 RESIDENTIAL WASHER
Kenmore 11045091401 RESIDENTIAL WASHER
Kenmore 11045091402 RESIDENTIAL WASHER
Kenmore 11045091403 RESIDENTIAL WASHER
Kenmore 11045091404 RESIDENTIAL WASHER
Kenmore 11045801400 WASHER
Kenmore 11045862400 RESIDENTIAL WASHER
Kenmore 11045862401 RESIDENTIAL WASHER
Kenmore 11045862402 RESIDENTIAL WASHER
Kenmore 11045862403 RESIDENTIAL WASHER
Kenmore 11045862404 RESIDENTIAL WASHER
Kenmore 11045872400 RESIDENTIAL WASHER
Kenmore 11045872401 RESIDENTIAL WASHER
Kenmore 11045872402 RESIDENTIAL WASHER
Kenmore 11045872403 RESIDENTIAL WASHER
Kenmore 11045872404 RESIDENTIAL WASHER
Kenmore 11045962400 RESIDENTIAL WASHER
Kenmore 11045962401 RESIDENTIAL WASHER
Kenmore 11045962402 RESIDENTIAL WASHER
Kenmore 11045962403 RESIDENTIAL WASHER
Kenmore 11045962404 RESIDENTIAL WASHER
Kenmore 11045966400 RESIDENTIAL WASHER
Kenmore 11045966401 RESIDENTIAL WASHER
Kenmore 11045966402 RESIDENTIAL WASHER
Kenmore 11045966403 RESIDENTIAL WASHER
Kenmore 11045966404 RESIDENTIAL WASHER
Kenmore 11045972400 RESIDENTIAL WASHER
Kenmore 11045972401 RESIDENTIAL WASHER
Kenmore 11045972402 RESIDENTIAL WASHER
Kenmore 11045972403 RESIDENTIAL WASHER
Kenmore 11045972404 RESIDENTIAL WASHER
Kenmore 11045976400 RESIDENTIAL WASHER
Kenmore 11045976401 RESIDENTIAL WASHER
Kenmore 11045976402 RESIDENTIAL WASHER
Kenmore 11045976403 RESIDENTIAL WASHER
Kenmore 11045976404 RESIDENTIAL WASHER
Kenmore 11045981400 RESIDENTIAL WASHER
Kenmore 11045986400 RESIDENTIAL WASHER
Kenmore 11045986401 RESIDENTIAL WASHER
Kenmore 11045986402 RESIDENTIAL WASHER
Kenmore 11045986403 RESIDENTIAL WASHER
Kenmore 11045986404 RESIDENTIAL WASHER
Kenmore 11045991400 RESIDENTIAL WASHER
Kenmore 11045992400 RESIDENTIAL WASHER
Kenmore 11045994400 RESIDENTIAL WASHER
Kenmore 11045994401 RESIDENTIAL WASHER
Kenmore 11045996400 RESIDENTIAL WASHER
Kenmore 11045996401 RESIDENTIAL WASHER
Kenmore 11045996402 RESIDENTIAL WASHER
Kenmore 11045996403 RESIDENTIAL WASHER
Kenmore 11045996404 RESIDENTIAL WASHER
Kenmore 11046462500 TECH SHEET
Kenmore 11046462501 RESIDENTIAL WASHER
Kenmore 11046472500 RESIDENTIAL WASHER
Kenmore 11046472501 RESIDENTIAL WASHER
Kenmore 11046742700 RESIDENTIAL WASHER
Kenmore 11046742701 RESIDENTIAL WASHER
Kenmore 11046742702 WASHER
Kenmore 11046747801 RESIDENTIAL WASHER
Kenmore 11046747802 WASHER
Kenmore 11046752700 RESIDENTIAL WASHER
  #2 (permalink)
Old 03-16-2012, 12:32 PM
Gary/APP Team's Avatar
Expert
Gary/APP Team is on a distinguished road
Default
Quote:
thanks jeff
Hello Jeff. Here is an attachment with the correct ohms for the door lock, You can test this with a multi-meter [AP3873826]. Here is a link on how to use a multi-meter. Hope this helps. If the door lock test good look to the control unit, How To Check Continuity With Ohmmeter.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
washer wont complete cycle nivek Washer Repair 4 05-16-2011 04:43 PM
Kenmore Washer - wont stop last spin cycle + how long spin cycle suppose to last? tc38 Washer Repair 3 04-29-2011 07:49 PM
Washer/dryer wont let me dry after cycle samanthaleah Dryer Repair 1 07-01-2009 04:34 PM
Washer wont drain until end of cycle gary123456 Washer Repair 1 06-25-2009 05:31 PM
