Discuss
washer overflow
 in
Washer Repair
Our washer overflowed all over the floor, luckily we were close by to stop it and I syphoned it immediately.
Appliance Repair Forum > Appliance Repair Help > Washer Repair » washer overflow
  #1 (permalink)
Old 08-13-2009, 10:59 AM
Junior Member
R Creation is on a distinguished road
Default washer overflow
Model Number: 11092596100   Brand: Kenmore   Age: More than 10 years
Our washer overflowed all over the floor, luckily we were close by to stop it and I syphoned it immediately. I think I may have found the cause and wondered if anyone concurred with my solution. It appears that the vacuum line to the level switch popped off allowing it to fill continuously, it has no hose clamp on it.
I also would like to clean out the possible slime that is causing the stinch but dont know how to get the top off so I can remove the washer basket if you will or tub, I have a feeling there is a build up at the drain. HELP
Ads By Google
Related Models
Kenmore 11092962100 WASHER DRYER LAUNDRY SYSTEM
Kenmore 11092962101 LAUNDRY SYSTEM
Kenmore 11092962102 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11092964100 WASHER DRYER LAUNDRY SYSTEM
Kenmore 11092964101 LAUNDRY SYSTEM
Kenmore 11092964102 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11092966100 WASHER DRYER LAUNDRY SYSTEM
Kenmore 11092966101 LAUNDRY SYSTEM
Kenmore 11092966102 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11092972100 WASHER DRYER LAUNDRY SYSTEM
Kenmore 11092972101 LAUNDRY SYSTEM
Kenmore 11092972102 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11092974100 WASHER DRYER LAUNDRY SYSTEM
Kenmore 11092974101 LAUNDRY SYSTEM
Kenmore 11092974102 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11092976100 WASHER DRYER LAUNDRY SYSTEM
Kenmore 11092976101 LAUNDRY SYSTEM
Kenmore 11092976102 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11094518200 COMPACT AUTOMATIC WASHER
Kenmore 11094518201 AUTOMATIC WASHER
Kenmore 11094518400 COMPACT AUTOMATIC WASHER
Kenmore 11094518401 AUTOMATIC WASHER
Kenmore 11094519100 WASHER
Kenmore 11094519800 WASHER
Kenmore 11094570100 COMPACT WASHER
Kenmore 11094570800 COMPACT WASHER
Kenmore 11094572200 COMPACT WASHER
Kenmore 11094572201 AUTOMATIC WASHER
Kenmore 11094572400 COMPACT WASHER
Kenmore 11094572401 AUTOMATIC WASHER
Kenmore 11094818200 AUTOMATIC WASHER
Kenmore 11094818400 AUTOMATIC WASHER
Kenmore 11094872200 COMPACT AUTOMATIC WASHER
Kenmore 11094872400 COMPACT AUTOMATIC WASHER
Kenmore 11095 CEILING FAN
Kenmore 11096195120 ELECTRIC DRYER
Kenmore 11096195500 ELECTRIC DRYER
Kenmore 11096195510 DRYER FEATURE SHEET
Kenmore 11096195520 ELECTRIC DRYER
Kenmore 11096195800 ELECTRIC DRYER
Kenmore 11096195810 DRYER FEATURE SHEET
Kenmore 11096195820 ELECTRIC DRYER
Kenmore 11096210100 DRYER-FEATURE SHEET
Kenmore 11096220100 DRYER-FEATURE SHEET
Kenmore 11096250100 DRYER-FEATURE SHEET
Kenmore 11096260100 DRYER FEATURE SHEET
Kenmore 11096263100 DRYER-FEATURE SHEET
Kenmore 11096263800 DRYER-FEATURE SHEET
Kenmore 11096264100 DRYER FEATURE SHEET
Kenmore 11096264800 DRYER FEATURE SHEET
Kenmore 11096271100 DRYER FEATURE SHEET
Kenmore 11096271600 DRYER FEATURE SHEET
Kenmore 11096271800 DRYER FEATURE SHEET
Kenmore 11096272000 ELECTRIC DRYER
Kenmore 11096272100 DRYER FEATURE SHEET
Kenmore 11096272600 DRYER FEATURE SHEET
Kenmore 11097091100 GAS DRYER
Kenmore 11097091300 GAS DRYER
Kenmore 11097091700 GAS DRYER
Kenmore 11097091800 GAS DRYER
Kenmore 11097093100 GAS DRYER
Kenmore 11097093300 GAS DRYER
Kenmore 11097093500 GAS DRYER
Kenmore 11097093700 GAS DRYER
Kenmore 11097093800 GAS DRYER
Kenmore 11097094100 GAS DRYER
Kenmore 11097094300 GAS DRYER
Kenmore 11097094500 GAS DRYER
Kenmore 11097094700 GAS DRYER
Kenmore 11097094800 GAS DRYER
Kenmore 11097195100 GAS DRYER
Kenmore 11097195110 DRYER FEATURE SHEET
Kenmore 11097195120 GAS DRYER
Kenmore 11097195500 GAS DRYER
Kenmore 11097195510 DRYER FEATURE SHEET
Kenmore 11097195520 GAS DRYER
Kenmore 11097195800 GAS DRYER
Kenmore 11097195810 DRYER FEATURE SHEET
Kenmore 11097195820 GAS DRYER
Kenmore 11097210100 DRYER-FEATURE SHEET
Kenmore 11097220100 DRYER-FEATURE SHEET
Kenmore 11097250100 DRYER-FEATURE SHEET
Kenmore 11097260100 DRYER FEATURE SHEET
Kenmore 11097264100 DRYER FEATURE SHEET
Kenmore 11097264800 DRYER FEATURE SHEET
Kenmore 11097271100 DRYER FEATURE SHEET
Kenmore 11097271600 DRYER FEATURE SHEET
Kenmore 11097271800 DRYER FEATURE SHEET
Kenmore 11097272100 DRYER FEATURE SHEET
Kenmore 11097272600 DRYER FEATURE SHEET
Kenmore 11097272800 DRYER SPECIFICATIONS
Kenmore 11097273100 DRYER FEATURE SHEET
Kenmore 11097273600 DRYER FEATURE SHEET
Kenmore 11097273800 DRYER FEATURE SHEET
Kenmore 11097274100 DRYER FEATURE SHEET
Kenmore 11097274600 DRYER FEATURE SHEET
Kenmore 11097274800 DRYER FEATURE SHEET
Kenmore 11097278100 DRYER FEATURE SHEET
Kenmore 11097278800 DRYER FEATURE SHEET
Kenmore 11097280100 DRYER FEATURE SHEET
Kenmore 110985000 SEARS DIRECT DISCHARGE WALL FAN
Kenmore 110985100 VERTICAL DISCHARGE FAN
Kenmore 11098518200 ELECTRIC DRYER
Kenmore 11098518210 ELECTRIC DRYER
Kenmore 11098518220 ELECTRIC DRYER
Kenmore 11098518230 COMPACT ELECTRIC DRYER
Kenmore 11098518400 ELECTRIC DRYER
Kenmore 11098518410 ELECTRIC DRYER
Kenmore 11098518420 ELECTRIC DRYER
Kenmore 11098518430 COMPACT ELECTRIC DRYER
Kenmore 110985200 SEARS HEATER/FAN/LIGHT
Kenmore 110985300 FAN/LIGHT
Kenmore 110985400 BULB HEATER/FANS
Kenmore 110985500 BULB HEATER/FANS
Kenmore 110985501 BULB HEATER/FAN
Kenmore 110985600 SEARS BATHROOM FANS
Kenmore 110985700 SEARS BATHROOM FANS
Kenmore 11098572200 ELECTRIC DRYER
Kenmore 11098572210 ELECTRIC DRYER
Kenmore 11098572400 ELECTRIC DRYER
  #2 (permalink)
Old 08-13-2009, 11:25 AM
Frank / APP Team's Avatar
Senior Expert
Frank / APP Team is on a distinguished road
Default
If that hose came off it would definitely cause the flood.
On this model the whole cabinet comes off, not just the top. If you remove the control panel, underneath it in each corner you'll see a retainer clip. With a screwdriver you can release them, be careful they're under tension. With those removed the cabinet will pivot forward, you will have to disconnect the lid switch wiring. From there you'll have access to what you're looking to do.
Be sure to unplug the power cord first.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 08-13-2009, 02:10 PM
Junior Member
Frank,
Thanks for the info, that should be the answer I needed. The other thing is the tray did not do its job because it ripped away from the wall pipe one time when the washer was out of balance. I'm trying to figure out how I'm going to get the unit into the new tray up over the lip once I install a new one.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer overflow nightglow1 Washer Repair 2 01-13-2010 01:36 PM
Washer won't spin or drain = overflow claudema Washer Repair 3 11-18-2009 05:14 PM
overflow Joesquich Washer Repair 2 03-30-2009 12:14 PM
Where can i find a Frigidaire Washer manual - overflow issue kevbayer Washer Repair 3 03-05-2009 01:15 PM
Whirlpool washer overflow mlp_deals Washer Repair 10 12-10-2008 10:31 AM
