| » Washer fills ok, won't go to next cycle |
Model Number: gst9679pw3 Brand: Whirlpool Age: 1 - 5 years
Washer is 3 yrs old. It fills ok, but won't go (start) next
cycle. I replaced the timer unit, but it did not cure the problem. I can get the washer to go , by rocking the hell out of it. It then completes all it's cycles. Help Please!! Thank You Val Cappo Ads By Google Related Models |
Quote:
Could possibly be the water level switch not giving the signal for the motor to start, although that doesn't fail very often. I would suggest you start looking at/unplugging then plugging back in your quick disconnect connectors. Sure sounds like you have a connection that isn't always making contact, and when you shake it, it's jarring it to the point it then contacts. You might want to start with the connection at the motor. Be sure to have the power removed when disconnecting any connectors. If you do them one at a time, and then plug the machine back in after disconnecting one, it would help you determine which one may be the culprit.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Just to add my 2 cents...
I would check the lid switch (#11 on the diagram), its wire harness plug and the lid hinges first. According to the wiring diagram this switch interrupts power to the motor. Loose lid hinge can cause the lid switch not to engage properly. - The lid switch Part number: AP3180933 Here are the breakdown diagrams and Replacement parts for WHIRLPOOL GST9679PW3 | AppliancePartsPros.com Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
| Display Modes | |
| washer fills very slow, rinse cycle | jrurig | Washer Repair | 1 | 01-14-2010 04:47 PM |
| Washer Passes Wash Cycle and Fills Up | PatrickB | Dishwasher Repair | 0 | 08-14-2009 04:46 PM |
| Washer fills with hot water after cycle done | jwallack | Washer Repair | 15 | 07-22-2009 07:55 PM |
| washer fills slow when it goes into rinse cycle | myparrot | Washer Repair | 1 | 10-15-2008 11:15 AM |
| Washer fills on wash cycle and rinse cycle and won't stop filling! | riphinney | Washer Repair | 15 | 03-12-2008 05:30 PM |
