Hi my front load washer(5 years old), made a loud sound all of the sudden during washing cycle. when i reach it i found it stopped on the spin cycle and making a buzzing sound. turn it off and on after few hours and restart the washing cycle, it works and agitate, once it reach the spin cycle it stops and make this buzzing sound. Any idea what might went wrong? Thanks
i see a lot of people viewed the post but no reply. just to let everyone knows that i found the issue :) . the washer did not drain that is why it did not spin. the reason it did not drain is a hair clip stuck in the water pump, i found this out when i took the water pump out.
