I have a sears stackable washer dryer that is at least 10 years old. It works fine except it is starting to leak at 2 of the bolts that go around the drum. I tightened them and it helped. But they still drip a little. Can I take the bolts out and use silicone between the plastic drum to stop the leak? Thank, Bob
It would be helpful if you could post the model number for us, thanks.
Hi, it is a Sears front loader. Model 417.4002990. Thanks, Bob
I gave the wrong model number. It should be, 417.40042990 Thanks, Bob
