Discuss
whirlpool duet washer won't drain
 in
Washer Repair
My whirlpool duet washer won't drain. It usually shuts off on rinse or spin. The code is f02 which would
Appliance Repair Forum > Appliance Repair Help > Washer Repair » whirlpool duet washer won't drain
  #1 (permalink)
Old 01-14-2008, 11:14 AM
Junior Member
linleason is on a distinguished road
Default whirlpool duet washer won't drain
Model Number: ghw9100lw1   Brand: Whirlpool   Age: 1 - 5 years
My whirlpool duet washer won't drain. It usually shuts off on rinse or spin. The code is f02 which would indicate the need for a new water pump, but the tub also won't spin. The water pump runs but is noisy. Does a faulty water pump stop the tub from moving or do we likely hava a nother problem in addition to the pump?thanks. We just bought this washer used.
Ads By Google
Related Models
Whirlpool GHW9100LW1
Whirlpool GHW9100LW2 Automatic Washer
Whirlpool GHW9150PW0 Automatic Washer
Whirlpool GHW9150PW1 Automatic Washer
Whirlpool GHW9150PW2 Automatic Washer
Whirlpool GHW9150PW3 Automatic Washer
Whirlpool GHW9150PW4 Automatic Washer
Whirlpool GHW9160PW0 Automatic Washer
Whirlpool GHW9160PW1 Automatic Washer
Whirlpool GHW9160PW2 Automatic Washer
Whirlpool GHW9160PW3 Automatic Washer
Whirlpool GHW9160PW4 Automatic Washer
Whirlpool GHW9200LQ0
Whirlpool GHW9200LW0
Whirlpool GHW9250ML0 Automatic Washer
Whirlpool GHW9250ML1 Automatic Washer
Whirlpool GHW9250ML2 Automatic Washer
Whirlpool GHW9250MQ0 Automatic Washer
Whirlpool GHW9250MQ1 Automatic Washer
Whirlpool GHW9250MQ2 Automatic Washer
Whirlpool GHW9250MT0 Automatic Washer
Whirlpool GHW9250MT1 Automatic Washer
Whirlpool GHW9250MT2 Automatic Washer
Whirlpool GHW9250MW0 Automatic Washer
Whirlpool GHW9250MW1 Automatic Washer
Whirlpool GHW9250MW2 Automatic Washer
Whirlpool GHW9300PW0 Automatic Washer
Whirlpool GHW9300PW1 Automatic Washer
Whirlpool GHW9300PW2 Automatic Washer
Whirlpool GHW9300PW3 Automatic Washer
Whirlpool GHW9300PW4 Automatic Washer
Whirlpool GHW9400PL0 Automatic Washer
Whirlpool GHW9400PL1 Automatic Washer
Whirlpool GHW9400PL2 Automatic Washer
Whirlpool GHW9400PL3 Automatic Washer
Whirlpool GHW9400PL4 Automatic Washer
Whirlpool GHW9400PT0 Automatic Washer
Whirlpool GHW9400PT1 Automatic Washer
Whirlpool GHW9400PT2 Automatic Washer
Whirlpool GHW9400PT3 Automatic Washer
Whirlpool GHW9400PT4 Automatic Washer
Whirlpool GHW9400PW0 Automatic Washer
Whirlpool GHW9400PW1 Automatic Washer
Whirlpool GHW9400PW2 Automatic Washer
Whirlpool GHW9400PW3 Automatic Washer
Whirlpool GHW9400PW4 Automatic Washer
Whirlpool GHW9400SU0 Automatic Washer
Whirlpool GHW9460PL0 Automatic Washer
Whirlpool GHW9460PL1 Automatic Washer
Whirlpool GHW9460PL2 Automatic Washer
Whirlpool GHW9460PL3 Automatic Washer
Whirlpool GHW9460PL4 Automatic Washer
Whirlpool GHW9460PW0 Automatic Washer
Whirlpool GHW9460PW1 Automatic Washer
Whirlpool GHW9460PW2 Automatic Washer
Whirlpool GHW9460PW3 Automatic Washer
Whirlpool GHW9460PW4 Automatic Washer
Whirlpool GHWT160JXX0
Whirlpool GI1500PHB0
Whirlpool GI1500PHB3
Whirlpool GI1500PHB4 Ice Cube Maker
Whirlpool GI1500PHB5 Ice Cube Maker
Whirlpool GI1500PHB6 Ice Cube Maker
Whirlpool GI1500PHB7 Ice Cube Maker
Whirlpool GI1500PHB8 Ice Cube Maker
Whirlpool GI1500PHW0
Whirlpool GI1500PHW3
Whirlpool GI1500PHW4 Ice Cube Maker
Whirlpool GI1500PHW5 Ice Cube Maker
Whirlpool GI1500PHW6 Ice Cube Maker
Whirlpool GI1500PHW7 Ice Cube Maker
Whirlpool GI1500PHW8 Ice Cube Maker
Whirlpool GI1500XHB0
Whirlpool GI1500XHB1
Whirlpool GI1500XHB2
Whirlpool GI1500XHB3
Whirlpool GI1500XHB4 Ice Cube Maker
Whirlpool GI1500XHB5 Ice Cube Maker
Whirlpool GI1500XHB6 Ice Cube Maker
Whirlpool GI1500XHB7 Ice Cube Maker
Whirlpool GI1500XHB8 Ice Cube Maker
Whirlpool GI1500XHB9 Ice Cube Maker
Whirlpool GI1500XHN0
Whirlpool GI1500XHN1
Whirlpool GI1500XHN2
Whirlpool GI1500XHN3
Whirlpool GI1500XHN4 Ice Cube Maker
Whirlpool GI1500XHS0
Whirlpool GI1500XHS1
Whirlpool GI1500XHS2
Whirlpool GI1500XHS3
Whirlpool GI1500XHS4 Ice Cube Maker
Whirlpool GI1500XHS5 Ice Cube Maker
Whirlpool GI1500XHS6 Ice Cube Maker
Whirlpool GI1500XHS7 Ice Cube Maker
Whirlpool GI1500XHS8 Ice Cube Maker
Whirlpool GI1500XHS9 Ice Cube Maker
Whirlpool GI1500XHT1
Whirlpool GI1500XHT2
Whirlpool GI1500XHT3
Whirlpool GI1500XHT4 Ice Cube Maker
Whirlpool GI1500XHT5 Ice Cube Maker
Whirlpool GI1500XHT6 Ice Cube Maker
Whirlpool GI1500XHT7 Ice Cube Maker
Whirlpool GI1500XHT8 Ice Cube Maker
Whirlpool GI1500XHT9 Ice Cube Maker
Whirlpool GI1500XHW0
Whirlpool GI1500XHW1
Whirlpool GI1500XHW2
Whirlpool GI1500XHW3
Whirlpool GI1500XHW4 Ice Cube Maker
Whirlpool GI1500XHW5 Ice Cube Maker
Whirlpool GI1500XHW6 Ice Cube Maker
Whirlpool GI1500XHW7 Ice Cube Maker
Whirlpool GI1500XHW8 Ice Cube Maker
Whirlpool GI1500XHW9 Ice Cube Maker
Whirlpool GI15NDXTB0 Ice Cube Maker
Whirlpool GI15NDXTB1 Ice Cube Maker
Whirlpool GI15NDXTQ0 Ice Cube Maker
Whirlpool GI15NDXTQ1 Ice Cube Maker
  #2 (permalink)
Old 01-14-2008, 08:01 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Check the drain pump filter (#14 on the pump & motor break down diagram) for a foreign objects and hoses for clog.
If there is nothing wrong - replace the pump.
- The part number for the drain pump is AP3953640
- Here are the break down diagrams for the Whirlpool Duet washer Model GHW9100LW1
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 12-06-2009, 04:36 PM
Junior Member
ybcool is on a distinguished road
Default
Hi! I have the same problem only the Washer Spins just fine. My Water Pump isn't noisy either. It just displays 'F02' when at the Drain Cycle. After it does this, I unplugged the Machine, removed the Drain Hose and also checked the Drain Hose outlet in the wall behind the Washer. I cleaned everything out and replaced all of it, then I tried it again starting from the Drain/Spin Cycle and it did it successfully. but when I try to start a whole new Wash Cycle, it gives the 'F02' error code again at the first Drain Cycle (after initial Wash). Please help me too. Thank you so much.
  #4 (permalink)
Old 12-07-2009, 01:42 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Check the pressure switch as described in the Service manual (page 5-6). Make sure the pressure hose is clean.
If there is nothing wrong, replace the CCU.
If you do need the correct part numbers, post the complete model number of the washer.
__________________
  #5 (permalink)
Old 12-09-2009, 06:08 PM
Junior Member
trnash9 is on a distinguished road
Default
Quote:
I think I know what the problem might be. I bought my washer used as well and had the same issue after about 4 months. First, disconnect the drain house from the back (the hose that goes to your wall). Take it it outside and blast a garden hose throught it (with a garden hose gun on the end to get good pressure). If that doesn't do it (like it didn't for me) you probably have something stuck where the water begins to drain from the drum (inside the washer). First, try to drain your washer using the drain/spin cycle. If your problem is real bad, this may not work. Then, open the back of it (you'll be surprised at how simple it looks inside). Get on the floor and look under the drum. You'll see a black, ribbed hose that is about 4 inches wide connected to the drum. You'll need to disconnect this...but, know that you'll get some water pouring out. I thought the water wasn't going to stop, but it wasn't too bad. Have about 3 big towels handy. After you remove this (and clean up the water, look at where the other end of that black hose is connected to. I reached in that little hole and pulled out a whole, adult wool sock, 2 baby socks, pieces of paper, coins and a couple of other things. The hole was only about 2 inches wide, and I couldn't believe how many things were in it. That is why I always use those mesh, lingerie bags for socks whenever I do laundry now. I guess the drain in the machine is so powerful that it can just suck socks (and probably wash cloths) and anything small through it. After you clean it out, just reattach the hose the way you took it off, put the back back on and you should be good to go. Good luck.
  #6 (permalink)
Old 05-07-2010, 09:44 AM
Junior Member
janmike2423 is on a distinguished road
Talking Whirpool Duet wont drain
First, You don't have to take the back off. If you take the cover off the bottom of the front there is a drain, the cover aka plug screws off, and lots of water will drain out. Clean out what ever is in there.. I had like lots of lint and debri. Simple easy....
  #7 (permalink)
Old 05-08-2010, 05:57 AM
Senior Expert
APP Volunteer
richappy is a name known to all
Default
Also, NEVER remove the tub hose at the tub. If you do, you will need to buy a new band clamp, as the spring clamp will be impossible to put back on!
__________________
  #8 (permalink)
Old 08-06-2010, 09:41 PM
Junior Member
ldaly210 is on a distinguished road
Default not quite right
I did as trnash9 said, after trying everything else. there was a big sock in the hose. i took a clamp and it now will not go on. besides buying a new clamp, any suggestions on how to re-attach this clamp?? thanks!!!
  #9 (permalink)
Old 11-10-2010, 10:57 AM
Junior Member
ggdave is on a distinguished road
Default
for an f2 code i start with the pump filter. remove lower front cover plate, remove wiring harness so you can access pump. unscrew pump filter cover. check filter for debris. careful as water will pour out. be prepared. you can remove tub to pump hose from here if necessary to clean further. Do this once a year as a maintenance item and you will save on replacing the pump. best thing is you do not have to pull out the washer. this is all done through the front, quick and easy!
  #10 (permalink)
Old 12-20-2010, 11:56 AM
Junior Member
pyro863 is on a distinguished road
Default
Quote:
Thanks for all the info didnt know that it even had a filter. It was full of garbage, and works great again Thanks
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Duet Will Not Drain luse241 Washer Repair 3 01-26-2010 03:45 PM
whirlpool duet washer will not drain and spin bcanebres Washer Repair 0 11-25-2009 07:57 AM
whirlpool duet washer doesnt drain rsine Washer Repair 1 10-24-2009 06:55 PM
Whirlpool Duet Sport washer seems stuck in drain cycle luistorres Washer Repair 6 09-28-2009 09:18 AM
Whirlpool duet won't drain CGH Washer Repair 6 01-24-2009 12:13 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
