Discuss
whirlpool duet washer won't drain
 in
Washer Repair
Hi Terry, It is a good idea to give it a try. If it would not solve the problem, you
Appliance Repair Forum > Appliance Repair Help > Washer Repair » whirlpool duet washer won't drain
  #21 (permalink)
Old 10-03-2011, 01:32 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Terry,
It is a good idea to give it a try. If it would not solve the problem, you can return the part to APP.
- The drain pump assembly Part number: AP3953640
Ads By Google
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #22 (permalink)
Old 10-11-2011, 12:32 PM
Junior Member
tcvon is on a distinguished road
Default
Gene,
I finally and reluctantly took your advice and replaced the pump motor.
It didn't totally make sense to me why replacing the pump would solve it, but I did it anyway and it WORKED. Our machine works just like new again.
FYI, when I pulled off the original motor and compared it to the new one, I noticed that the impeller and shaft on the old motor, was extended out from the winding housing about 1/2". I was able to push it back in with ease.
Also, I did this right after a load finished and found the motor to be quite hot. Not too hot that I couldn't hold on to it, but hot enough for concern.
I don't know much about electric motors. I thought when they went bad, they just quit. This one seems to have been dying a slow death.
Thanks for your help !
  #23 (permalink)
Old 10-11-2011, 03:14 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You are welcome. I'm glad it's up and running.
__________________
  #24 (permalink)
Old 10-17-2011, 06:30 AM
Junior Member
hayshaker is on a distinguished road
Default Whirlpool Duet washer won't drain
I'm new to this forum. I'm very impressed. For the last 16 years I've made my living by repairing Janitorial equipment ( vacuums, buffers, burnishers, shampoo machines, etc.) My whirlpool duet won't drain. Fixing this problem seemed to be a very daunting task. I want to thank every one of you for your questions and answers. Especially the service manual link and how to get the parts.
  #25 (permalink)
Old 09-04-2012, 06:06 PM
Junior Member
scmom1968 is on a distinguished road
Default
When you start to clean it out after removing the front cover, have the shop vac handy to suck up any water and it will also suck out any gunk that is stuck in there. Ours was clogged with those laundry sheets that have both the detergent and fabric softener on them. Will never buy those again!
  #26 (permalink)
Old 11-13-2012, 01:53 PM
Junior Member
cofccougar is on a distinguished road
Default F02 Error
I have done everything I know to resolve my issue. I cleaned the filter, then replaced the drain pump. Still working sporadically. When I try the drain setting, the machine starts to drain, then it seems that there is a problem with the pump creating a suction issue. The black hose from the drum to the filter gets sucked into itself like there is something creating a vacuum. It feels like there is a ball of some sort in the hose right below the drum. I think this is causing the vacuum.??? Of course, I can't take the pump back because it is an electrical item. $125 down the tubes.
Ideas??? Any help is greatly appreciated!
  #27 (permalink)
Old 11-13-2012, 02:34 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Very likely there is a foreign object(s) floating between the outer and the inner tubs which are blocking the drain hose. You may want to use the instructions posted by trnash9 on the previous page of this thread to inspect them.
BTW, ANY parts ordered from APP can be returned even if they were installed.
__________________
  #28 (permalink)
Old 11-14-2012, 05:04 AM
Junior Member
Default F02 Error
Thanks Gene,
I'll give it a try. From what I've read, I guess I'm gonna need a band clamp to replace the spring clamp that's on it now for the re-install.
  #29 (permalink)
Old 11-14-2012, 09:54 AM
Junior Member
Default F02 Error
After taking the drum to filter hose off I see the problem: looks like 3 washer/dryer sheets!!! The worst product ever!!! Taking the hose off was no problem. Putting it back on from the front was an almost impossible task so I took the back off and had it back on in no time. The spring band clamp was not a problem to get back on either. No need to get a new one.
Thanks Gene!
I should have came to the forum before spending the $125 for a new drain pump I didn't need. Oh well, I guess I have a spare in case the new one bites the dust.
  #30 (permalink)
Old 11-14-2012, 01:07 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You are welcome. We're glad to hear we could help you out. If there is anything else we can help you with, drop us a line.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Duet Sport washer seems stuck in drain cycle luistorres Washer Repair 7 10-05-2012 11:52 AM
Whirlpool Duet Will Not Drain luse241 Washer Repair 3 01-26-2010 03:45 PM
whirlpool duet washer will not drain and spin bcanebres Washer Repair 0 11-25-2009 07:57 AM
whirlpool duet washer doesnt drain rsine Washer Repair 1 10-24-2009 06:55 PM
Whirlpool duet won't drain CGH Washer Repair 6 01-24-2009 12:13 PM
