Discuss
Washer leaks long after cycle is complete
 in
Washer Repair
I have an LG washer that has developed a leak At first I thought it was cominf from the seal
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer leaks long after cycle is complete
  #1 (permalink)
Old 03-13-2012, 06:56 PM
Junior Member
snooks100 is on a distinguished road
Question Washer leaks long after cycle is complete
Model Number: WM2277H   Brand: -other-   Age: 5 - 10 years
I have an LG washer that has developed a leak At first I thought it was cominf from the seal at the back of the drum, but I now think that it may be the drain hose, as the majority of the water on the floor appears long after the washer has completed its wash cycle (>30 minutes).
Does my diagnoses sound reasonable?
Does the replacement drain (part # AP4457291 I think) )hose come with installation instructions?
Thank you in advance
Ads By Google
Related Models
Jenn-Air WM227B Walloven - S/c Mwave Ele
Jenn-Air WM227W Walloven - S/c Mwave Ele
Jenn-Air WM236B Walloven - S/c Mwave Ele
Jenn-Air WM236W Walloven - S/c Mwave Ele
Jenn-Air WM27160B Walloven - S/c Mwave Ele
Jenn-Air WM27160W Walloven - S/c Mwave Ele
Jenn-Air WM2720B Walloven - S/c Mwave Ele
Jenn-Air WM2720W Walloven - S/c Mwave Ele
Jenn-Air WM27260B Walloven - S/c Mwave Ele
Jenn-Air WM27260W Walloven - S/c Mwave Ele
Jenn-Air WM27460B Walloven - S/c Mwave Ele
Jenn-Air WM27460W Walloven - S/c Mwave Ele
Jenn-Air WM2750B Walloven - S/c Mwave Ele
Jenn-Air WM2750W Walloven - S/c Mwave Ele
Jenn-Air WM277B Walloven - S/c Mwave Ele
Jenn-Air WM277W Walloven - S/c Mwave Ele
Jenn-Air WM2780 Walloven - S/c Mwave Ele
Jenn-Air WM2780B Walloven - S/c Mwave Ele
Jenn-Air WM2780W Walloven - S/c Mwave Ele
Jenn-Air WM30460B Walloven - S/c Mwave Ele
Jenn-Air WM30460W Walloven - S/c Mwave Ele
Amana WM612 Mwave - Cntrtp / Stand Alone
Amana WM614 Mwave - Cntrtp / Stand Alone
Amana WM615 Mwave - Cntrtp / Stand Alone
Amana WM712 Mwave - Cntrtp / Stand Alone
Amana WM714 Mwave - Cntrtp / Stand Alone
Amana WM715 Mwave - Cntrtp / Stand Alone
General Electric WMCD2050G0WC Washer
Jenn-Air WME3020B Walloven - S/c Mwave Ele
Jenn-Air WME3020W Walloven - S/c Mwave Ele
Jenn-Air WMG3020B Walloven - S/c Mwave Gas
Jenn-Air WMG3020W Walloven - S/c Mwave Gas
General Electric WMR04BANABB Refrigerator
General Electric WMR04BANBBB Refrigerator
General Electric WMR04BANCBB Refrigerator
General Electric WMR04BANDBB Refrigerator
General Electric WMR04BAPABB Refrigerator
General Electric WMR04DATABB Refrigerator
General Electric WMSE3140A0AA Washer
General Electric WMSE3140A0WW Washer
General Electric WMSE3140A2WW Washer
General Electric WMSE3140A3WW Washer
General Electric WMSE4190A0AA Washer
General Electric WMSE4190A0WW Washer
General Electric WMSE4230A0WW Washer
General Electric WMSR2090T2AA Washer
General Electric WMSR2090T2WW Washer
General Electric WMSR2090T3AA Washer
General Electric WMSR2090T3WW Washer
General Electric WMSR2090T5AA Washer
General Electric WMSR2090T5WW Washer
General Electric WMSR2100T6AA Washer
General Electric WMSR2100T6WW Washer
General Electric WMSR2100T8AA Washer
General Electric WMSR2100T8WW Washer
General Electric WMSR2100TAAA Washer
General Electric WMSR2100TAWW Washer
General Electric WMSR2100TBAA Washer
General Electric WMSR2100TBWW Washer
General Electric WMSR3110W1WW Washer
General Electric WMSR3110W2WW Washer
General Electric WMXR3080T2AA Washer
General Electric WMXR3080T2WW Washer
General Electric WMXR3080T3AA Washer
General Electric WMXR3080T3WW Washer
General Electric WMXR3080T5AA Washer
General Electric WMXR3080T5WW Washer
General Electric WMXR3080T6AA Washer
General Electric WMXR3080T6WW Washer
General Electric WMXR3080T8AA Washer
General Electric WMXR3080T8WW Washer
General Electric WMXR3080TAAA Washer
General Electric WMXR3080TAWW Washer
Bosch WMZ2200
General Electric WNCD2050A0WC Washer
General Electric WNCD2050A1WC Washer
General Electric WNCD2050A2WC Washer
General Electric WNCD2050A9WC Washer
General Electric WNCD2050B9WC Washer
General Electric WNCJ2050A0WC Washer
General Electric WNCJ2050A1WC Washer
General Electric WNCJ2050D0WC Washer
General Electric WNCK2050A0WC Washer
General Electric WNCK2050A1WC Washer
General Electric WNCK2050D0WC Washer
General Electric WNCK2050D1WC Washer
General Electric WNCK2050D1WW Washer
General Electric WNRD2050D0WC Washer
General Electric WNRD2050D1WW Washer
General Electric WNRD2050DCWC Washer
General Electric WNRE6280D0WW Washer
General Electric WNSB8060B0CC Washer
General Electric WNSB8060B0WW Washer
General Electric WNSB8060B1CC Washer
General Electric WNSB8060B1WW Washer
General Electric WNSB8060B9CC Washer
General Electric WNSB8060B9WW Washer
General Electric WNSB9080B0CC Washer
General Electric WNSB9080B0WW Washer
General Electric WNSB9100B0CC Washer
General Electric WNSB9100B0WW Washer
General Electric WNSE4200A0AA Washer
General Electric WNSE4200A0WW Washer
General Electric WNSE5260D0WW Washer
General Electric WNSE5260D1WW Washer
General Electric WNSE5699A0AA Washer
General Electric WNSE5699A0WW Washer
General Electric WNSE6280B0WW Washer
General Electric WNSE6280B1WW Washer
General Electric WNSE6280B2WW Washer
General Electric WNSE6280B3WW Washer
General Electric WNSR2100T2AA Washer
General Electric WNSR2100T2WW Washer
  #2 (permalink)
Old 03-14-2012, 01:02 PM
Member
Markram is on a distinguished road
Default
I suggest that you investigate the leak more prior to purchasing a drain hose. If the drain hose was leaking, then it would most likely be leaking prior to 30 minutes after use.
Look around where you see water. Sometimes you can see a water trail from certain place to lead you to where it is leaking.
Is it leaking from front? Rear?
There are a lot of causes for leaks, so you will need to investigate more to narrow it down.
  #3 (permalink)
Old 03-14-2012, 01:04 PM
Member
Default
I have seen a drain hose leaking from a small hole chewed through by a rodent... just a thought.
You could always put down some towels or something that would show you where it was leaking from to narrow it down.
Is the water dirty, brown or greasy?
  #4 (permalink)
Old 03-14-2012, 01:42 PM
Junior Member
Default More info
Maybe my original post wasn't great.
The leak appears to be coming from the rear left corner (as viewed from the front). A damp spot will appear on the floor during the wash cycle, but it becomes a puddle over time - after the cycle has stopped.
How quickly the puddle forms I cannot say, but if it is only a small leak, then it would seem that very little would leak out during the cycle when water is being pushed past it at speed, and that more would leak out when the washer had stopped and the water sat in the drain hose. Perhaps it would run along the inner lip of the washer side to the rear, where it would find a hole to leak out through. (Just postulating here. :~? )
I took the back off the washer and observed it during a wash cycle, but no clear origination point was seen. What I did see were intermittent drops on the drain hose/washer side, but I could not tell where they were coming from, as it did not leak enough while I was observing it to isolate the problem area.
I cannot tell the color/texture as it is in a dark area on a cement floor. I would say that it is mostly clear.
Does any of this make it more clear?
  #5 (permalink)
Old 03-14-2012, 02:09 PM
Member
Default
There is an air vent on that side of unit, and excessive sudsing during a spin cycle (which happens to be end of cycle) will push out some of the suds and cause a small amount of water to leak out vent.
That is one possible reason.
There is always water in some part of the drain hose after a wash. So it you clean up water after use - that leaked out - and then allow unit to stand a couple of days, and no water has leaked out hose, then it is not your drain hose most likely.
If it only happens at the end of a wash and no other time... it could likely be the air vent and sudsing....
You can use less soap or HE detergent.
Usually a hole in a hose will cause more water to leak and will keep on leaking when unit is not in use.
Difficult to diagnose without investigating. Leaks can be elusive to find...
  #6 (permalink)
Old 03-14-2012, 05:39 PM
Junior Member
Default
Markram - Thanks for all your advice/suggestions.
Water does continued to appear for quite a long time after the cycle is completed and I have cleaned it up several times - which is why I thought about the drain hose, knowing that it would still have water in it.
Where is this air vent located? Since it is more than just a small amount (standing water easily covers a 6" x 15" area to ~1/8" depth), I doubt that this would be the source based on your description.
I'll keep looking in hopes of finding something, but I am not hopeful.
  #7 (permalink)
Old 03-15-2012, 03:35 PM
Member
Default
Air vent is at top left rear of unit.
There is no easy thing to tell you for a leak. You basically have to find where it is leaking and then go from there.
There are too many places for a washer to leak and without being there, its difficult to tell.
  #8 (permalink)
Old 03-20-2012, 03:41 PM
Junior Member
Default
I've got it now - at least 99% sure I have. :-)
I made sure that none of the drain hoses were leaking, and then I took the top off in search of the air vent. No leak there either.
But, what I found was the hot water inlet valve/solenoid was not fully closing and it was leaking. That is why the water continued to appear after the machine had stopped - because we don't turn the water off unless we are leaving for a trip.
Does that sound reasonable?
Have you heard of many of these failing?
Should I replace the cold water valve/solenoid at the same time just to be sure?
Thanks for urging me to keep checking.
  #9 (permalink)
Old 12-20-2012, 07:08 AM
Junior Member
Default
Just wanted to give an update on this.
I replaced the hot water solenoid (easy fix) and that has solved the problem.
(I should have posted this long ago, but kept getting side-tracked, snd then just forgot. :~( )
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer won't complete cycle dmacza Washer Repair 0 03-12-2011 03:55 PM
Washer Will Not Complete A Cycle salamo Washer Repair 0 08-13-2010 06:04 PM
Any suggestions on why washer leaks from underneath AFTER cycle is complete? Brigitte Washer Repair 1 06-23-2010 02:35 PM
washer does not complete cycle genogene Washer Repair 1 01-03-2010 04:49 PM
GE washer won't complete cycle damselNdistress Washer Repair 13 06-05-2009 06:23 AM
