Discuss
Washer won't drain/spin in rinse cylce
 in
Washer Repair
Our washing machine (Estate TAWB600EQ1, almost 9 years old) won't autmoatically continue to the drain part of the rinse
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer won't drain/spin in rinse cylce
  #1 (permalink)
Old 01-14-2008, 09:10 AM
jimII jimII is offline
Junior Member
jimII is on a distinguished road
Default Washer won't drain/spin in rinse cylce
Model Number: TAWB600EQ1   Brand: Estate   Age: 5 - 10 years
Our washing machine (Estate TAWB600EQ1, almost 9 years old) won't autmoatically continue to the drain part of the rinse cycle. (Up to that point it works like a champ.) However, if I manually depress the lid switch for two-three seconds and immediately close the lid, it then finishs the rinse cycle just fine.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-14-2008, 06:30 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Most likely the problem is a bad lid switch.
- The part number for the lid switch is AP3100003
- Here are the break down diagrams for the Estate washer Model TAWB600EQ1
Good luck.
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 01-15-2008, 12:30 AM
Junior Member
Default
Thanks for the quick reply. Much appreciated!
jim
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer will not drain or spin fenderi Washer Repair 3 01-19-2008 10:17 AM
Help!! Washer Want Drain Or Spin rpearce Washer Repair 2 12-14-2007 04:37 PM
washer will not spin or drain Martha Shelby Washer Repair 2 10-25-2007 03:43 AM
washer will not spin or drain Martha Shelby Washer Repair 1 10-24-2007 04:59 AM
Washer won't drain or spin carrol Washer Repair 2 08-20-2007 07:37 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
