Discuss
Kenmore 90 plus series washer
 in
Washer Repair
I have a Kenmore 90 plus series. This morning I started a load of laundry. When I returned more than
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kenmore 90 plus series washer
  #1 (permalink)
Old 08-11-2009, 01:05 PM
Junior Member
eclay is on a distinguished road
Default Kenmore 90 plus series washer
Model Number: 11028932790   Brand: Kenmore   Age: More than 10 years
I have a Kenmore 90 plus series. This morning I started a load of laundry. When I returned more than 20 min. the washer was still filling to the point that I had water all over the floor. What I have been able to determine is that when the washer is filling up it never stops. If I manually stop the washer by pushing in the nob then turn it to the next phase after filling it will go until it starts filling up again and never go beyond that point. I read on a post somewhere that a kenmore series 70 with the sam problem they checked the preasure valve. Looking on the Kenmore parts site it doesn't look like that part exist or it is caled something else.
What part determines when to stop filling and how do I test it?
Related Models
Kenmore 11028932790 AUTOMATIC WASHER
Kenmore 11028932791 AUTOMATIC WASHER
Kenmore 11028934790 AUTOMATIC WASHER
Kenmore 11028934791 AUTOMATIC WASHER
Kenmore 11028942890 Residential Washers
Kenmore 11028942891 AUTOMATIC WASHER
Kenmore 11028944890 Residential Washers
Kenmore 11028944891 AUTOMATIC WASHER
Kenmore 11028972890 AUTOMATIC WASHER
Kenmore 11028972891 AUTOMATIC WASHER
Kenmore 11028974890 AUTOMATIC WASHER
Kenmore 11028974891 AUTOMATIC WASHER
Kenmore 11029012990 COMMERICAL AUTOMATIC WASHER
Kenmore 11029032990 COMMERCIAL AUTOMATIC WASHER
Kenmore 11029072990 COMMERCIAL AUTOMATIC WASHER
Kenmore 11029422800 RESIDENTIAL WASHER
Kenmore 11029422801 RESIDENTIAL WASHER
Kenmore 11029432800 WASHER
Kenmore 11029432801 RESIDENTIAL WASHER
Kenmore 11029442800 RESIDENTIAL WASHER
Kenmore 11029442801 RESIDENTIAL WASHER
Kenmore 11029522800 RESIDENTIAL WASHER
Kenmore 11029522801 RESIDENTIAL WASHER
Kenmore 11029532800 RESIDENTIAL WASHER
Kenmore 11029532801 RESIDENTIAL WASHER
Kenmore 11029592800 RESIDENTIAL WASHER
Kenmore 11029592801 RESIDENTIAL WASHER
Kenmore 11029622800 RESIDENTIAL WASHER
Kenmore 11029622801 RESIDENTIAL WASHER
Kenmore 11029632800 RESIDENTIAL WASHER
Kenmore 11029632801 RESIDENTIAL WASHER
Kenmore 11029672800 RESIDENTIAL WASHER
Kenmore 11029672801 RESIDENTIAL WASHER
Kenmore 11029682800 RESIDENTIAL WASHER
Kenmore 11029682801 RESIDENTIAL WASHER
Kenmore 11029692800 RESIDENTIAL WASHER
Kenmore 11029692801 RESIDENTIAL WASHER
Kenmore 1102970093 COMPACT AUTOMATIC WASHER
Kenmore 11029722800 RESIDENTIAL WASHER
Kenmore 11029722801 RESIDENTIAL WASHER
Kenmore 11029727800 RESIDENTIAL WASHER
Kenmore 11029727801 RESIDENTIAL WASHER
Kenmore 11029732800 WASHER
Kenmore 11029732801 RESIDENTIAL WASHER
Kenmore 11029737800 WASHER
Kenmore 11029737801 RESIDENTIAL WASHER
Kenmore 11029802890 AUTOMATIC WASHER
Kenmore 11029812890 AUTOMATIC WASHER
Kenmore 11029812891 AUTOMATIC WASHER
Kenmore 11029822800 WASHER
Kenmore 11029822801 RESIDENTIAL WASHER
Kenmore 11029832800 WASHER
Kenmore 11029832801 RESIDENTIAL WASHER
Kenmore 11029842990 WASHER
Kenmore 11029842991 AUTOMATIC WASHER
Kenmore 11029852990 AUTOMATIC WASHER-GALAXY
Kenmore 11029852991 AUTOMATIC WASHER
Kenmore 11029852992 AUTOMATIC WASHER
Kenmore 11029882890 AUTOMATIC WASHER
Kenmore 11029882891 AUTOMATIC WASHER
Kenmore 11029884890 AUTOMATIC WASHER
Kenmore 11029884891 AUTOMATIC WASHER
Kenmore 11029892990 AUTOMATIC WASHER-TECH SHEET
Kenmore 11029894990 AUTOMATIC WASHER-TECH SHEET
Kenmore 11029962890 AUTOMATIC WASHER
Kenmore 11029962891 AUTOMATIC WASHER
Kenmore 1103348565 GEARCASE
Kenmore 110357116 GEARCASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110357177 GEARCASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110357970 BASKET DRIVE AND BRAKE ASM
Kenmore 110357972 GEAR CASE AND SUPERSTRUCTURE
Kenmore 110358364 BASKET DRIVE AND BRAKE ASM
Kenmore 110358365 GEAR CASE AND SUPERSTRUCTURE
Kenmore 110358371 GEARCASE AND SUPERSTRUCTURE
Kenmore 110358483 GEARCASE ASM
Kenmore 110358484 GEARCASE AND SUPERSTRUCTURE
Kenmore 110358485 GEARCASE AND SUPERSTRUCTURE
Kenmore 110358487 GEARCASE AND SUPERSTRUCTURE
Kenmore 110358507 GEAR CASE AND SUPERSTRUCTURE
Kenmore 110358795 GEAR CASE AND SUPERSTRUCTURE
Kenmore 110358841 GEARCASE AND SUPERSTRUCTURE
Kenmore 110359175 BASKET DRIVE & BRAKE ASM
Kenmore 110359178 GEAR CASE AND SUPERSTRUCTURE
Kenmore 110359279 GEARCASE PARTS
Kenmore 110359517 BASKET DRIVE AND BRAKE PARTS
Kenmore 110359699 BASKET DRIVE AND BRAKE PARTS
Kenmore 110360093 AMERICAN STANDARD MIXING VALVE ASSEMBLY
Kenmore 110360867 DOLE MIXING VALVE ASSEMBLY
Kenmore 110360868 AMERICAN STANDARD MIXING VALVE ASSEMBLY
Kenmore 110362101 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110362901 GEARCASE ASM
Kenmore 110363000 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110363082 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110364443 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110364444 BASKET DRIVE AND BRAKE PARTS
Kenmore 110364446 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110364494 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110365011 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110365012 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110365014 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110365359 GEARCASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110365712 GEARCASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110365859 GEARCASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110366660 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110366990 BASKET DRIVE & BRAKE ASM
Kenmore 110367551 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110367593 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 1103733107 KENMORE PORTABLE AUTOMATIC WASHER
Kenmore 110389246 GEARCASE PARTS
Briggs & Stratton 110402-0180-E1 ENGINE
Kenmore 11042182200 AUTOMATIC WASHER
Kenmore 11042182201 AUTOMATIC WASHER
Kenmore 11042722200 AUTOMATIC WASHER
Kenmore 11042722201 AUTOMATIC WASHER
Kenmore 11042822200 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11042822201 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11042822202 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11042822203 AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 11042824200 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11042824201 AUTOMATIC WASHER HORIZONTAL AXIS
  #2 (permalink)
Old 08-11-2009, 01:18 PM
Frank / APP Team's Avatar
Senior Expert
Frank / APP Team is on a distinguished road
Default
The part that tells the water valve to shut off is called the water level switch(pressure switch). You also need to make sure nothing has happened to the hose that goes from the water level switch down to the outer tub. Sometimes they can get a hole in them and the air pressure that's required to activate the switch is never achieved. The hose could also get blocked with lint, etc.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 08-11-2009, 02:00 PM
Junior Member
Default
Quote:
The hose looks like it attached to the switch and the tub. I gave it a tug and it didn't come off the connection to the tub so I believe that isn't the problem. I took to the water level switch off and will replace it.
Thanks for the quick reply.
  #4 (permalink)
Old 08-11-2009, 09:17 PM
Senior Expert
APP Volunteer
magician59 will become famous soon enough
Default
Water level switches very rarely fail, unless a hole develops in the diaphragm. As Frank stated, a clogged air hose, or a hole in the hose will cause an overfill situation. But another common cause of overfilling is a fouled water inlet valve. Debris from the water source will prevent the solenoid from completely closing. You can test for this by starting a fill, and unplugging the machine. If it continues to fill after you unplug it, replace the water valve.
  #5 (permalink)
Old 08-11-2009, 10:33 PM
Junior Member
Default
Quote:
I found a crack in the hose. I replaced it and it seems to be working now.
  #6 (permalink)
Old 10-02-2010, 02:26 PM
Junior Member
Drew II is on a distinguished road
Default Kenmore Series 90 still overfilling
Thanks for the idea about unlplugging the washer...however once I unplugged the washer, the water stopped. I am able to drain it, but I have to trick the washer by manually advancing the control dial. With that scenario, what do you think is the cause?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Washer Series 90 Tony A Washer Repair 6 12-09-2011 07:06 PM
Kenmore 90 Series Washer Mr Lee Washer Repair 1 01-16-2010 05:04 PM
Kenmore Series 90 washer dguern1 Washer Repair 3 07-10-2009 08:23 PM
Kenmore series 90 washer Glen Barclay Washer Repair 7 10-22-2008 01:53 PM
Kenmore 90 Plus Series Washer jeremyh65 Washer Repair 5 02-27-2008 12:35 PM
