Appliance Repair Forum
-   Washer Repair (http://forum.appliancepartspros.com/washer-repair/)
-   -   Washer showing error (http://forum.appliancepartspros.com/washer-repair/43778-washer-showing-error.html)
shark6558 08-11-2009 07:42 AM
Hello, This is my first time using this and obviously i have a question. My girlfriend started the washing maching and didnt put in a pair of pants needed to be washed. Realizing this she hit cancel on the machine to put the pant in and as she tried to start the machine again it showed error on the screen and every button you push shows error. I have unplugged it to fix the problem and it did not work. It is also blinking the number 47 which i beleive is the minutes left on the wahing cycle. If you have any idea how to fix this problem please let me know. thank you
sidfink43 08-12-2009 12:30 PM
Here is the service manual which will take you through trouble shooting and diagnostic routines.
http://frigidaireservicetips.com/pdf...sherManual.pdf
I am afraid at the end of the day you will be talking about a new control board, but this model also has a motor control board which fails frquently so you want to narrow things down.
Hopefully it is none of these and the trouble shooting will show you a way to reset it and have it working again.
Good luck.
