Discuss
Only on rinse cycle washer won't fill up with water, goes right to the drain hose
 in
Washer Repair
Why is it only on the rinse cycle, that the washer begins to fill with water but never fills. Lifted
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Only on rinse cycle washer won't fill up with water, goes right to the drain hose
  #1 (permalink)
Old 08-09-2009, 03:24 PM
Junior Member
pmmcadams is on a distinguished road
Default Only on rinse cycle washer won't fill up with water, goes right to the drain hose
Brand: -other-   Age: Less than 1 year
Why is it only on the rinse cycle, that the washer begins to fill with water but never fills. Lifted the drain hose out of the drain and it is going straight to the drain. It was doing this for about 2 hours before I realized it. What is causing this and why only on the rinse cycle?
  #2 (permalink)
Old 08-10-2009, 03:33 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
What is the complete model number of the washer?
If it is less than a year old then call for the warranty service.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer stops at Rinse Cycle and doesn't drain water kukoch Washer Repair 12 03-06-2013 02:35 PM
Dishwasher won't fill w/ water except during rinse cycle rocklorrie Dishwasher Repair 0 08-07-2009 10:41 PM
GE dishwasher, water will not drain after rinse cycle..... FDAR Dishwasher Repair 3 07-29-2009 07:57 AM
Washer does not start rinse, will not fill with cold water Gene51 Washer Repair 10 06-27-2009 04:09 PM
Need HELP! Water will not drain after rinse cycle coxcox2u Washer Repair 2 04-14-2009 06:45 PM
