GE Washer-
Belt Broke, Replaced Belt. Tried the "lid reset" after unplugging and repluggin, but motor doesn't seem to want to turn back on.
It drains some , but doesnt spin or agitate.
Suggestions ?
Very little information... Your belt broke. That is somewhere to start though.
You will want to find out why the belt broke. Will the basket turn easily by hand? Does the motor hum when it is supposed to come on?
You mentioned the water will drain some. Do you mean it will not drain all the way? If not, there may be an obstruction in pump or line. Pump impeller could have failed.
Some units will not spin if water will not drain.
I suggest providing more information or starting with those things...
