Discuss
Loud bang bang on spin in front load frigidaire
 in
Washer Repair
I have a lound bang from tub hitting back panel on spin check shock there good the inside of tub
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Loud bang bang on spin in front load frigidaire
  #1 (permalink)
Old 03-08-2012, 11:02 AM
Junior Member
jontalbott is on a distinguished road
Default Loud bang bang on spin in front load frigidaire
Brand: Frigidaire   Age: 1 - 5 years
I have a lound bang from tub hitting back panel on spin check shock there good the inside of tub when I move up and down and back an forth has no bearing movemount. tired balancing wash did no good what am I missing.
Ads By Google
  #2 (permalink)
Old 03-08-2012, 12:02 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
You possibly have a broken spring on the top. Take off the cover and check both springs. To get you the part numbers and the instructions provide complete model number.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 03-09-2012, 04:25 PM
Member
Markram is on a distinguished road
Default
You wrote that it has no bearing movement, what do you mean by that? If the inner basket will not spin freely and smoothly, then you have a bearing problem and the rear outer tub will need to be replaced, and if the spindle is bent or damaged, then the basket will also need to be replaced.
Sometimes the pulley can become bent at the rear of tub and can sometimes cause issues, but this usually results in the belt coming off pulley.
Check your owners manual to see how long the basket is covered - assuming that you would need to order one.
Hopefully it is an easy fix though.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool - Loud Bang or Clunk gamadmex Washer Repair 1 01-20-2012 02:16 PM
A bang or loud knock at end of spin cycle GaryGan Washer Repair 1 11-01-2011 06:12 PM
Whirlpool washer goes BANG BANG BANG - with video! ScottyP5947 Washer Repair 5 03-23-2009 12:10 AM
Washe makes loud bang at the end of spin cycle SUETOO Washer Repair 1 01-01-2008 01:23 PM
Loud Bang from Stove djtone1000 Oven Repair (including Ranges and Cooktops) 1 08-11-2007 04:42 PM
