I Have Searched Several Forums And Cant Find Solution. My Washer/ Dryer Combo Will Fill With Water, Jump Like Its Going To Agitate But Will Not. It Times Thru To Next Cycle And Spins For About 5 Seconds Then Quits. It Will Not Drain. Also, If I Replace Parts On Washer, Do I Have To Take The Units Apart To Repair. Any Help/advice Is Greatly Appreciated. If Not Fixed Soon My Wife Is Going To Hurt Me. Thanks
The first thing you want to check is whether or not something is caught in the pump. So take off the transition panel and then take off the cabinet and check it out.
If there is nothing from stopping the motor from turning in the pump then see if the transmission will turn by hand. If it will the problem may be the motor, if not it may be the transmission.
Originally Posted by: mud736 I Have Searched Several Forums And Cant Find Solution. My Washer/ Dryer Combo Will Fill With Water, Jump Like Its Going To Agitate But Will Not. It Times Thru To Next Cycle And Spins For About 5 Seconds Then Quits. It Will Not Drain. Also, If I Replace Parts On Washer, Do I Have To Take The Units Apart To Repair. Any Help/advice Is Greatly Appreciated. If Not Fixed Soon My Wife Is Going To Hurt Me. Thanks If this is the laundry center, remove front panel and check the wiring harness on the right inside at the seam running from lid switch backwards, many times this wiring harness has been partially or fully severed by the tub baning into it at that seam area. Just a tip... If that is ok, and is not smashed or cut.... then it might be transmission if unit will not agitate or spin... you'll just have to do some checks and investigating.
