Our washing machine fills and spins but it will not aggitate in the wash or the rinse cycle, not sure what it is, also on a tight budget so cant call a repairman have to fix it myself.
Originally Posted by: Drozz Our washing machine fills and spins but it will not aggitate in the wash or the rinse cycle, not sure what it is, also on a tight budget so cant call a repairman have to fix it myself. Hello. It sounds like the thrust Part number: AP4009132
bearing is stuck not letting the brake release ,that is why it will still spin , Thank you and good luck !
