| » Washer leak water to floor |
Model Number: WBB4500G1WW Brand: GE Age: 5 - 10 years
Please help, today I replaced the flood hose (AP2046588), and flood gasket (AP2044901) to my GE washer, during agitating, water still come out and flooded my floor, I don't know what else I need to replace to avoid anymore spilling out of the hose, any suggestion or ideas will be greatly appreciated.
Quote:
A couple of things to check, Make sure the Flood hose head gasket(inside the tub) is seated and facing down , properly. and the connections are tight. Make sure the tub cover gasket and cover are seated properly and clipped doen tightly and check to insure the washer is not overfilling, disconnect the air dome hose from the water level switch and blow into it to clear any possible debris. You're sure the leak is from the left rear corner of the tub assembly, and not from the fill valve or a damaged tub seal ? Good Luck and Thanks,
__________________
Thanks for allowing AppliancePartsPros.com to assist you, Joe M. APP TEAM Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Quote:
__________________
Hello Gary, I did try the water valve test, the water did stop immediately when I unplug the washer, the pressure switch and hose you describing I am not sure what to look for, the model is GE WBB4500G1WW, thanks for the quick reply.
Check for a pin hole or a very small crack , sometimes mice will nibble on the hoses looking for water or something soft to chew on
__________________
| Display Modes | |
| Refrigerator Leak on floor | akpark | Refrigerator & Freezer Repair | 0 | 08-08-2010 12:41 PM |
| washer leaking water and oil or grease on the floor under it | asnowangel2000 | Washer Repair | 2 | 04-13-2009 04:40 PM |
| freezer leaks water on floor and freezes in floor | bcarolan | Refrigerator & Freezer Repair | 10 | 04-04-2009 10:52 AM |
| Ice collecting on freezer floor and water on floor under door hinge | paddison51 | Refrigerator & Freezer Repair | 3 | 02-26-2009 04:52 AM |
| My washer fills and works okay but water seems to flood my floor | ztait | Washer Repair | 0 | 07-02-2008 10:42 AM |
