Discuss
Error Code F6
 in
Washer Repair
I KEEP GETTING ERROR CODE F6, I WENT THRU THE PAPER WORK AND CHECKED EVERYTHING WHIRLPOOL TOLD ME TO CHECK.
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Error Code F6
  #1 (permalink)
Old 08-05-2009, 04:43 PM
Junior Member
MOTOJOE is on a distinguished road
Default Error Code F6
Model Number: GHW9150PW4   Brand: Whirlpool   Age: 1 - 5 years
I KEEP GETTING ERROR CODE F6, I WENT THRU THE PAPER WORK AND CHECKED EVERYTHING WHIRLPOOL TOLD ME TO CHECK. SHOULD REPLACE THE MOTOR OR IS THERE SOMETHING ELSE I SHOULD LOOK FOR. THANKS I CHECKED A FEW MORE THINGS OUT AND IT WILL NOT SPIN OUT BUT IT WILL SPIN THRU THE WASH CYCLE AND WILL PUMP THE WATER OUT BUT IT WILL NOT SPIN WHEN IT IS TIME FOR THE SPIN CYCLE, THE MOTOR IS NOT MAKING ANY KIND OF NOISE WHAT SO EVER ON THE WASH CYCLE WHEN THE DRUM IS SPINNING. I AM STILL UP IN THE AIR ON WHAT PART TO GO TO FIRST AND CHANGE.
Related Models
Whirlpool GHW9150PW4 AUTOMATIC WASHER
Whirlpool GHW9160PW0 AUTOMATIC WASHER
Whirlpool GHW9160PW1 AUTOMATIC WASHER
Whirlpool GHW9160PW2 AUTOMATIC WASHER
Whirlpool GHW9160PW3 AUTOMATIC WASHER
Whirlpool GHW9160PW4 AUTOMATIC WASHER
Whirlpool GHW9200LQ0 WASHER
Whirlpool GHW9200LW0 WASHER
Whirlpool GHW9250ML0 AUTOMATIC WASHER
Whirlpool GHW9250ML1 AUTOMATIC WASHER
Whirlpool GHW9250ML2 AUTOMATIC WASHER
Whirlpool GHW9250MQ0 AUTOMATIC WASHER
Whirlpool GHW9250MQ1 AUTOMATIC WASHER
Whirlpool GHW9250MQ2 AUTOMATIC WASHER
Whirlpool GHW9250MT0 AUTOMATIC WASHER
Whirlpool GHW9250MT1 AUTOMATIC WASHER
Whirlpool GHW9250MT2 AUTOMATIC WASHER
Whirlpool GHW9250MW0 AUTOMATIC WASHER
Whirlpool GHW9250MW1 AUTOMATIC WASHER
Whirlpool GHW9250MW2 AUTOMATIC WASHER
Whirlpool GHW9300PW0 AUTOMATIC WASHER
Whirlpool GHW9300PW1 AUTOMATIC WASHER
Whirlpool GHW9300PW2 AUTOMATIC WASHER
Whirlpool GHW9300PW3 AUTOMATIC WASHER
Whirlpool GHW9300PW4 AUTOMATIC WASHER
Whirlpool GHW9400PL0 AUTOMATIC WASHER
Whirlpool GHW9400PL1 AUTOMATIC WASHER
Whirlpool GHW9400PL2 AUTOMATIC WASHER
Whirlpool GHW9400PL3 AUTOMATIC WASHER
Whirlpool GHW9400PL4 AUTOMATIC WASHER
Whirlpool GHW9400PT0 AUTOMATIC WASHER
Whirlpool GHW9400PT1 AUTOMATIC WASHER
Whirlpool GHW9400PT2 AUTOMATIC WASHER
Whirlpool GHW9400PT3 AUTOMATIC WASHER
Whirlpool GHW9400PT4 AUTOMATIC WASHER
Whirlpool GHW9400PW0 AUTOMATIC WASHER
Whirlpool GHW9400PW1 AUTOMATIC WASHER
Whirlpool GHW9400PW2 AUTOMATIC WASHER
Whirlpool GHW9400PW3 AUTOMATIC WASHER
Whirlpool GHW9400PW4 AUTOMATIC WASHER
Whirlpool GHW9400SU0 AUTOMATIC WASHER
Whirlpool GHW9460PL0 AUTOMATIC WASHER
Whirlpool GHW9460PL1 AUTOMATIC WASHER
Whirlpool GHW9460PL2 AUTOMATIC WASHER
Whirlpool GHW9460PL3 AUTOMATIC WASHER
Whirlpool GHW9460PL4 AUTOMATIC WASHER
Whirlpool GHW9460PW0 AUTOMATIC WASHER
Whirlpool GHW9460PW1 AUTOMATIC WASHER
Whirlpool GHW9460PW2 AUTOMATIC WASHER
Whirlpool GHW9460PW3 AUTOMATIC WASHER
Whirlpool GHW9460PW4 AUTOMATIC WASHER
General Electric GHWP1000M0WW WASHER
General Electric GHWP1000M1WW WASHER
Whirlpool GHWT160JXX0 HOT WATER DISPENSER
Whirlpool GI0FSAXVA00 REFRIGERATOR
Whirlpool GI0FSAXVA01 REFRIGERATOR
Whirlpool GI0FSAXVB00 REFRIGERATOR
Whirlpool GI0FSAXVB01 REFRIGERATOR
Whirlpool GI0FSAXVB02 REFRIGERATOR
Whirlpool GI0FSAXVB03 REFRIGERATOR
Whirlpool GI0FSAXVB04 REFRIGERATOR
Whirlpool GI0FSAXVB05 REFRIGERATOR
Whirlpool GI0FSAXVB06 REFRIGERATOR
Whirlpool GI0FSAXVB07 REFRIGERATOR
Whirlpool GI0FSAXVQ00 REFRIGERATOR
Whirlpool GI0FSAXVQ01 REFRIGERATOR
Whirlpool GI0FSAXVY00 REFRIGERATOR
Whirlpool GI0FSAXVY01 REFRIGERATOR
Whirlpool GI0FSAXVY02 REFRIGERATOR
Whirlpool GI0FSAXVY03 REFRIGERATOR
Whirlpool GI0FSAXVY04 REFRIGERATOR
Whirlpool GI0FSAXVY05 REFRIGERATOR
Whirlpool GI0FSAXVY06 REFRIGERATOR
Whirlpool GI0FSAXVY07 REFRIGERATOR
Whirlpool GI0FSAXVY08 REFRIGERATOR
Whirlpool GI1500PHB0 ICE CUBE MAKER
Whirlpool GI1500PHB2 ICE CUBE MAKER
Whirlpool GI1500PHB3 ICE MAKER - FREESTANDING
Whirlpool GI1500PHB4 ICE CUBE MAKER
Whirlpool GI1500PHB5 ICE CUBE MAKER
Whirlpool GI1500PHB6 ICE CUBE MAKER
Whirlpool GI1500PHB7 ICE CUBE MAKER
Whirlpool GI1500PHB8 ICE CUBE MAKER
Whirlpool GI1500PHW0 ICE CUBE MAKER
Whirlpool GI1500PHW2 ICE CUBE MAKER
Whirlpool GI1500PHW3 ICE MAKER - FREESTANDING
Whirlpool GI1500PHW4 ICE CUBE MAKER
Whirlpool GI1500PHW5 ICE CUBE MAKER
Whirlpool GI1500PHW6 ICE CUBE MAKER
Whirlpool GI1500PHW7 ICE CUBE MAKER
Whirlpool GI1500PHW8 ICE CUBE MAKER
Whirlpool GI1500XHB0 ICE CUBE MAKER
Whirlpool GI1500XHB1 ICE CUBE MAKER
Whirlpool GI1500XHB2 ICE CUBE MAKER
Whirlpool GI1500XHB3 ICE CUBE MAKER
Whirlpool GI1500XHB4 ICE CUBE MAKER
Whirlpool GI1500XHB5 ICE CUBE MAKER
Whirlpool GI1500XHB6 ICE CUBE MAKER
Whirlpool GI1500XHB7 ICE CUBE MAKER
Whirlpool GI1500XHB8 ICE CUBE MAKER
Whirlpool GI1500XHB9 ICE CUBE MAKER
Whirlpool GI1500XHN0 ICE CUBE MAKER
Whirlpool GI1500XHN1 ICE CUBE MAKER
Whirlpool GI1500XHN2 ICE CUBE MAKER
Whirlpool GI1500XHN3 ICE CUBE MAKER
Whirlpool GI1500XHN4 ICE CUBE MAKER
Whirlpool GI1500XHS0 ICE CUBE MAKER
Whirlpool GI1500XHS1 ICE CUBE MAKER
Whirlpool GI1500XHS2 ICE CUBE MAKER
Whirlpool GI1500XHS3 ICE CUBE MAKER
Whirlpool GI1500XHS4 ICE CUBE MAKER
Whirlpool GI1500XHS5 ICE CUBE MAKER
Whirlpool GI1500XHS6 ICE CUBE MAKER
Whirlpool GI1500XHS7 ICE CUBE MAKER
Whirlpool GI1500XHS8 ICE CUBE MAKER
Whirlpool GI1500XHS9 ICE CUBE MAKER
Whirlpool GI1500XHT1 ICE CUBE MAKER
Whirlpool GI1500XHT2 ICE CUBE MAKER
Whirlpool GI1500XHT3 ICE CUBE MAKER
Whirlpool GI1500XHT4 ICE CUBE MAKER
  #2 (permalink)
Old 08-07-2009, 02:31 PM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
Take off the bottom front panel and you should find some tech notes and troubleshooting routines.
Run through them and see if you can determine the problem or narrow it down. Your problem is probably in the motor/motor control unit/wiring/ccu areas, but those are pretty big areas, and you do not want to replace parts without a high probability you are solving the problem.
Also, clean out the water drain and pump, and see if that helps.
Here is the service manual.
https://secured.whirlpool.com/Servic...0Job%20Aid.pdf
Good luck, let us know what you find out.
__________________
  #3 (permalink)
Old 08-07-2009, 04:25 PM
Junior Member
Default Motor Control Unit
I CHANGED THE MOTOR CONTROL UNIT AND THE WIRE HARNESS TO THE MOTOR AND SO FAR SO GOOD. I WANT TO SEE IT RUN A FEW MORE LOADS OF WASH BEFORE I SAY THE PROBLEM IS FIXED. THANKS FOR THE REPLY AND I HOPE THIS HELPS OUT FOR OTHERS. THANKS
  #4 (permalink)
Old 08-07-2009, 04:50 PM
Senior Expert
APP Volunteer
Default
That should do it. That error message is not all that specific but what you did was the right thing and I am glad it is working.
Thanks for updating us. That will help us and others.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE error code F3 Mako Oven Repair (including Ranges and Cooktops) 21 06-04-2014 01:44 AM
error code 40 kimbrecht69@hotmail.com Oven Repair (including Ranges and Cooktops) 1 11-03-2010 12:07 AM
frigidaire error code F10 - not listed in your error codes Skully26 Oven Repair (including Ranges and Cooktops) 2 02-16-2010 04:29 AM
F33 error code daphil Washer Repair 1 03-27-2008 06:02 PM
error code f13 banks Oven Repair (including Ranges and Cooktops) 1 01-17-2008 11:11 AM
