ostoyichva
#1 Posted : Wednesday, August 5, 2009 11:22:36 AM(UTC)
ostoyichva
washer goes through washing cycle. when it changes to drain and spin it is very sluggish, dimming the overhead light and then tripping the breaker. the overhead light is on another circuit. what does it sound like to you. there is also a hot smell. the length of time it takes to spin and trip the breaker is approximately 30 to 60 seconds.
#2 Posted : Wednesday, August 5, 2009 1:55:59 PM(UTC)
Remove the front panel. Tilt the washer back, remove the belt and check how freely the pump pulley is moving in both directions. Post the results.
Here are the breakdown diagrams and Replacement parts for MAYTAG PAV2300AWW | AppliancePartsPros.com
ostoyichva
#3 Posted : Wednesday, August 5, 2009 3:41:07 PM(UTC)
ostoyichva
did not remove front panel. belt is underneath washer. belt removed. pump pulley moves relatively freely in both directions. what next.
ostoyichva
#4 Posted : Wednesday, August 5, 2009 3:54:46 PM(UTC)
ostoyichva
#5 Posted : Friday, August 7, 2009 4:33:19 PM(UTC)
Sorry for the delay.
Run the washer on spin without the belt. It it happens again then the motor has gone bad.
- The motor Part number: AP4024680
Kenmore washer trips breaker on slow speed (Washer Repair)
by hrasco 1/18/2014 1:21:32 PM(UTC)
Turning on washer trips breaker (Washer Repair)
by JoeFin 12/16/2013 3:25:06 PM(UTC)
Dishwasher Trips breaker (Dishwasher Repair)
by ddippel71 11/14/2009 12:05:28 PM(UTC)
Kenmore washer trips breaker... (Washer Repair)
by E.J.W. 9/23/2009 4:04:51 AM(UTC)
Washer trips breaker (Washer Repair)
by dbayless82 2/2/2009 8:49:40 PM(UTC)
Washer trips breaker in agitation or spin cycle (Washer Repair)
by bearysp 12/22/2008 3:04:08 PM(UTC)
