Discuss
drum does not hold water
 in
Washer Repair
The water comes on and drains right away, drum does not hold water. It would do this occassionally, now it's
Appliance Repair Forum > Appliance Repair Help > Washer Repair » drum does not hold water
  #1 (permalink)
Old 03-04-2012, 03:09 PM
Junior Member
Patnjasmine is on a distinguished road
Default drum does not hold water
Brand: Whirlpool   Age: 5 - 10 years
The water comes on and drains right away, drum does not hold water. It would do this occassionally, now it's all the time
  #2 (permalink)
Old 03-05-2012, 09:21 AM
Senior Member
allen9258 is on a distinguished road
will the spin cycle work? test the spin cycle set the timer to spin then depress the lid switch to see if it spins if it does then that's good now when the washer start filling does it fill to the desired level or does it start draining before it reaches the desired level is reached? you need to be more information with the question you are asking
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer won't hold water bommom Washer Repair 1 03-31-2011 07:41 AM
new kenmore won't hold water josefchak Garbage Disposer Repair 0 03-24-2011 12:32 PM
washer will not hold water lavadora Washer Repair 1 07-03-2009 05:52 PM
Whirlpool won't hold water TomH Washer Repair 0 10-22-2008 08:30 AM
Washer won't hold water mlj410 Washer Repair 2 04-02-2008 06:48 AM
