Discuss
Removing the top of a washer/dryer combination unit.
 in
Washer Repair
I needd to replace the lid switch on this washer/dryer unit. To do this I assume I will need to
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Removing the top of a washer/dryer combination unit.
  #1 (permalink)
Old 03-03-2012, 07:32 PM
Junior Member
no1shrink is on a distinguished road
Default Removing the top of a washer/dryer combination unit.
Model Number: LTE5243BW2   Brand: Whirlpool   Age: More than 10 years
I needd to replace the lid switch on this washer/dryer unit. To do this I assume I will need to remove the top of the washer to access the switch and the switch assembly. When I remove the angled panel that runs from the bottom of the washer to the top from edge of the dryer I have access to the dryer ducts and the faucets for the washer. I couldn't find the switch assembly though. Nor did I see how to remove the top.
If I need to gain access to the back of the unit I will have to move it away from the wall. I assume this will also entail detaching the dryer duct. Am I correct?
Related Models
Whirlpool LTE5243BW2 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5243DQ0 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5243DQ1 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5243DQ2 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5243DQ3 LAUNDRY CENTER
Whirlpool LTE5243DQ4 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5243DQ5 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5243DQ6 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5243DQ7 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5243DQ8 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5243DQ9 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5243DQA WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5243DT2 LAUNDRY SYSTEM
Whirlpool LTE5243DT3 LAUNDRY CENTER
Whirlpool LTE5243DT4 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5243DT5 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5243DT6 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5243DT7 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5243DZ0 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5243DZ1 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5243DZ2 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5500W1 ELECTRIC DRYER
Whirlpool LTE6234AN0 WASHER/DRYER
Whirlpool LTE6234AN1 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6234AN2 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6234AN3 COMBINATION UNITS
Whirlpool LTE6234AW0 WASHER/DRYER
Whirlpool LTE6234AW1 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6234AW2 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6234AW3 COMBINATION UNITS
Whirlpool LTE6234DQ0
Whirlpool LTE6234DQ1 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6234DQ2 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6234DQ3 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6234DQ4 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6234DQ5 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6234DQ6 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6234DT2 LAUNDRY CENTER
Whirlpool LTE6234DT3 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6234DT4 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6234DT5 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6234DT6 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6234DZ0
Whirlpool LTE6234DZ1 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6234DZ2 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6243AN2 LAUNDRY CENTER
Whirlpool LTE6243AW2 LAUNDRY CENTER
Whirlpool LTE7245AN0 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE7245AW0 WASHER/DRYER LAUNDRY SYSTEM
Frigidaire LTF1670DS0 Frigidaire/washer
Admiral LTF1812ARB REF - TOP MOUNT
Admiral LTF1812ARW REF - TOP MOUNT
Admiral LTF1812ARZ REF - TOP MOUNT
Admiral LTF2112ARB REF - TOP MOUNT
Admiral LTF2112ARW REF - TOP MOUNT
Admiral LTF2112ARZ REF - TOP MOUNT
Frigidaire LTF2140ES0 Frigidaire/washer
Frigidaire LTF2140ES1 Frigidaire/washer
Frigidaire LTF2140ES2 Frigidaire/washer
Frigidaire LTF2140ES3 Frigidaire/washer
Frigidaire LTF2140FS0 Frigidaire/washer
Frigidaire LTF2140FS1 WASHER
Frigidaire LTF2140FS2 WASHER
Frigidaire LTF2940EE0 Frigidaire/washer
Frigidaire LTF2940ES0 Frigidaire/washer
Frigidaire LTF2940ES1 Frigidaire/washer
Frigidaire LTF2940ES2 Frigidaire/washer
Frigidaire LTF2940ES3 Frigidaire/washer
Frigidaire LTF2940FE0 Frigidaire/washer
Frigidaire LTF2940FE1 WASHER
Frigidaire LTF2940FS1 WASHER
Frigidaire LTF530DS0 Frigidaire/washer
Frigidaire LTF530DS1 Frigidaire/washer
Frigidaire LTF530FS0 Frigidaire/washer
Frigidaire LTF530FS1 WASHER
Frigidaire LTF6000ES0 Frigidaire/washer
Frigidaire LTF6000ES1 Frigidaire/washer
Frigidaire LTF6000FS0 Frigidaire/washer
Frigidaire LTF6700FS0 WASHER
Frigidaire LTF7000EG0 Frigidaire/washer
Frigidaire LTF7000ES0 Frigidaire/washer
Frigidaire LTF7000ES1 Frigidaire/washer
Frigidaire LTF7000FG0 Frigidaire/washer
Frigidaire LTF8000FE0 WASHER
Whirlpool LTG5243BN0 WASHER-DRYER LAUNDRY SYSTEM
Whirlpool LTG5243BN1 WASHER-DRYER LAUNDRY SYSTEM
Whirlpool LTG5243BN2 WASHER-DRYER LAUNDRY SYSTEM
Whirlpool LTG5243BW0 WASHER-DRYER LAUNDRY SYSTEM
Whirlpool LTG5243BW1 WASHER-DRYER LAUNDRY SYSTEM
Whirlpool LTG5243BW2 WASHER-DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DQ0 WASHER-DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DQ1 WASHER-DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DQ2 WASHER-DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DQ3 WASHER-DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DQ4 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DQ5 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DQ6 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DQ7 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DQ8 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DQ9 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DQA WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DT2 WASHER-DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DT3 WASHER-DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DT4 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DT5 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DT6 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DT7 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DT8 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DZ0 WASHER-DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DZ1 WASHER-DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DZ2 WASHER-DRYER LAUNDRY SYSTEM
Whirlpool LTG6234AN0 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG6234AN1 COMBINATION UNITS
Whirlpool LTG6234AN2 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG6234AN3 COMBINATION UNITS
Whirlpool LTG6234AW0 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG6234AW1 COMBINATION UNITS
Whirlpool LTG6234AW2 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG6234AW3 COMBINATION UNITS
Whirlpool LTG6234DQ0
  #2 (permalink)
Old 03-05-2012, 06:01 PM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
See if this link to the service manual for the stacked unit will work for you
http://appliancejunk.com/forums/inde...;sa=view;id=30
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE combination washer/dryer does not agitate txcajun Washer Repair 0 01-26-2012 03:40 PM
GE combination washer/dryer does not agitate txcajun Washer Repair 0 01-26-2012 03:35 PM
No spin cycle Combination Washer/Dryer hann_fam Washer Repair 2 08-01-2009 09:01 AM
Stacked combination washer dryer Steve Bennett Dryer Repair 2 08-05-2008 01:04 PM
Oven / Microwave Combination Wall Unit LaVinnia Microwave Repair 4 03-10-2008 10:26 AM
