I need help with my front load washer...I bought it from someone and it never came with an owners manual. It worked perfectly for several months but just today I noticed it was getting hot inside when I was washing in cold water and now it won't drain the water. A code F03 shows in the time display window. What does that mean and what shall I fix?
Hi Solitary The F03 code is a problem with your water system. Sounds like your inlet valves may have failed, but hard to tell from here. Open up the bottom panel and you will find a tech sheet that will explain the codes and give you some trouble shooting techniques. Also, here is the service manual http://frigidaireservicetips.co...thElectronicControls.pdfGood luck, if you need more info let us know what you learned and what you need.
