Discuss
Maytag Neptune Combo Washer/ Dryer wont spin (washer)
 in
Washer Repair
Hello all, I'm having an issue with my Maytag MLG2000AWW Washer/ Dryer combo. Everything works fine with the washer and
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Maytag Neptune Combo Washer/ Dryer wont spin (washer)
  #1 (permalink)
Old 03-03-2012, 08:29 AM
Junior Member
HLSerrano is on a distinguished road
Default Maytag Neptune Combo Washer/ Dryer wont spin (washer)
Model Number: mlg2000aww   Brand: Maytag   Age: 5 - 10 years
Hello all, I'm having an issue with my Maytag MLG2000AWW Washer/ Dryer combo. Everything works fine with the washer and dryer except that the washer doesn't spin at the correct speed to remove the water from the clothes. The pump is fine because it drains the machine, the motor also functions correctly and the belt has tension. I'm a novice tinkerer but I did much more to troubleshoot the machine than the technician who charged $70 to tell me that the control board needed to be changed at the additional cost of $450 without even opening any of the access panels. I browsed through this site and found that others had changed the board and the machine continued to have the same problem. I would be forever grateful if someone can please assist me with some sound advise before I spend hundreds of dollars on trying to repair this unit. I feel comfortable and confident in swapping out defective electrical parts if needed to save hundreds of dollars.
Related Models
Maytag MLG2000AWW STACKED LAUNDRY- GAS
Maytag MLG2000AXW STACKED LAUNDRY- GAS
Maytag MLG23MNAWW MANUAL, PARTS (DRYER GAS)
Maytag MLG23MNFWW MAYTAG LAUNDRY (DRYER GAS)
Maytag MLG23PDAGW MANUAL, PARTS (DRYER ELE)
Maytag MLG23PDAWQ MAYTAG LAUNDRY (DRYER GAS)
Maytag MLG23PDAWW MAYTAG LAUNDRY (DRYER GAS)
Maytag MLG23PDAYQ MAYTAG LAUNDRY (DRYER GAS)
Maytag MLG23PDFGW MAYTAG LAUNDRY (DRYER GAS)
Maytag MLG23PDFWW MAYTAG LAUNDRY (DRYER ELE)
Maytag MLG23PDFXW MAYTAG LAUNDRY (DRYER ELE)
Maytag MLG23PDHGW MAYTAG LAUNDRY (DRYER ELE)
Maytag MLG23PDHWW MAYTAG LAUNDRY (DRYER ELE)
Maytag MLG23PDHXW MAYTAG LAUNDRY (DRYER ELE)
Maytag MLG23PRAWW MAYTAG LAUNDRY (DRYER GAS)
Maytag MLG23PRFWW MAYTAG LAUNDRY (DRYER GAS)
Maytag MLG23PRFXW MAYTAG LAUNDRY (DRYER GAS)
Maytag MLG24PDAGW0 COMMERCIAL GAS DRYER
Maytag MLG24PDAWW0 COMMERCIAL GAS DRYER
Maytag MLG24PDAWW1 COMMERCIAL GAS DRYER
Maytag MLG24PDAXW0 COMMERCIAL GAS DRYER
Maytag MLG24PDAXW1 COMMERCIAL GAS DRYER
Maytag MLG24PNAGW0 COMMERCIAL GAS DRYER
Maytag MLG24PRAWW0 COMMERCIAL GAS DRYER
Maytag MLG24PRAWW1 COMMERCIAL GAS DRYER
Maytag MLG31PCAWQ MAYTAG LAUNDRY (DRYER GAS)
Maytag MLG31PCAWS MAYTAG LAUNDRY (DRYER GAS)
Maytag MLG31PCAWW MAYTAG LAUNDRY (DRYER GAS)
Maytag MLG31PCBWQ MAYTAG LAUNDRY (DRYER GAS)
Maytag MLG31PCBWS MAYTAG LAUNDRY (DRYER GAS)
Maytag MLG31PCBWW MAYTAG LAUNDRY (DRYER GAS)
Maytag MLG32PDAWA MANUAL, PARTS (DRYER GAS)
Maytag MLG32PDAWW MANUAL, PARTS (DRYER GAS)
Maytag MLG32PDBWA MANUAL, PARTS (DRYER GAS)
Maytag MLG32PDBWQ MANUAL, PARTS (DRYER GAS)
Maytag MLG32PDBWS MAYTAG LAUNDRY (DRYER GAS)
Maytag MLG32PDBWW MANUAL, PARTS (DRYER GAS)
Maytag MLG33PDAWS MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MLG33PDAWW MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MLG33PDSWS MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MLG33PDSWW MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MLI7000AAW SMALL APPLIANCES
Maytag MLI7500AAW SMALL APPLIANCES
Admiral MLR1100AJQ RANGE- F/S STD GAS
Admiral MLR1100AJW RANGE- F/S STD GAS
Admiral MLR1110AJQ RANGE- F/S STD GAS
Admiral MLR1110AJW RANGE- F/S STD GAS
Admiral MLR1415AJQ RANGE- F/S STD GAS
Admiral MLR1415AJS RANGE- F/S STD GAS
Admiral MLR1415AJW RANGE- F/S STD GAS
Admiral MLR4410BXH RANGE- F/S STD GAS
Admiral MLR4410BXL RANGE- F/S STD GAS
Admiral MLR4410BXT RANGE- F/S STD GAS
Admiral MLR4410CXH RANGE- F/S STD GAS
Admiral MLR4410CXT RANGE- F/S STD GAS
Admiral MLR4451AJQ RANGE- F/S STD GAS
Admiral MLR4451AJS RANGE- F/S STD GAS
Admiral MLR4451AJW RANGE- F/S STD GAS
Admiral MLR5755QDS RANGE- S/C F/S GAS
Admiral MLR5755QDW RANGE- S/C F/S GAS
Frigidaire MLSE62RFD0 Frg(v1) / Laundry Center
Frigidaire MLSE62RFD1 Frg(v1) / Laundry Center
Frigidaire MLSE62RFW0 Frg(v2) / Laundry Center
Frigidaire MLSE62RFW1 Frg(v2) / Laundry Center
Frigidaire MLSE62RFW2 Frg(v0) / Laundry Center
Frigidaire MLSG62RFD0 Frg(v1) / Laundry Center
Frigidaire MLSG62RFD1 Frg(v1) / Laundry Center
Frigidaire MLSG62RFW0 Frg(v2) / Laundry Center
Frigidaire MLSG62RFW1 Frg(v2) / Laundry Center
Frigidaire MLXE42RBD0 Frg(v2) / 27 " Laundry Center
Frigidaire MLXE42RBD1 Frg(v1) / 27 " Laundry Center
Frigidaire MLXE42RBD2 Frg(v1) / Laundry Center
Frigidaire MLXE42RBD3 Frg(v1) / Laundry Center
Frigidaire MLXE42RBW0 Tap(v4) / 27 " Laundry Center
Frigidaire MLXE42RBW1 Frg(v2) / 27 " Laundry Center
Frigidaire MLXE42RBW2 Frg(v2) / Laundry Center
Frigidaire MLXE42RBW3 Frg(v2) / Laundry Center
Frigidaire MLXE42RBWD0 Kel(v10) / 27 " Laundry Center
Frigidaire MLXE42RED0 Frg(v1) / Laundry Center
Frigidaire MLXE42RED3 Frg(v1) / Laundry Center
Frigidaire MLXE42RED4 Frg(v1) / Laundry Center
Frigidaire MLXE42RED5 Frg(v1) / Laundry Center
Frigidaire MLXE42REW0 Frg(v2) / Laundry Center
Frigidaire MLXE42REW1 Frg(v0) / Laundry Center
Frigidaire MLXE42REW2 Frg(v0) / Laundry Center
Frigidaire MLXE42REW3 Frg(v2) / Laundry Center
Frigidaire MLXE42REW4 Frg(v2) / Laundry Center
Frigidaire MLXE42REW5 Frg(v2) / Laundry Center
Frigidaire MLXE42REW6 Laundry Center - Universal
Frigidaire MLXE42REW7 Universal/laundry Center
Frigidaire MLXE42REW8 Universal/laundry Center
Frigidaire MLXE42RFW0 Universal/laundry Center
Frigidaire MLXE62RBD0 Frg(v2) / 27 " Electric Laundry Center
Frigidaire MLXE62RBD1 Frg(v1) / 27 " Electric Laundry Center
Frigidaire MLXE62RBD2 Frg(v1) / Laundry Center
Frigidaire MLXE62RBD3 Frg(v1) / Laundry Center
Frigidaire MLXE62RBW0 Tap(v4) / 27 " Electric Laundry Center
Frigidaire MLXE62RBW1 Frg(v2) / 27 " Electric Laundry Center
Frigidaire MLXE62RBW2 Frg(v2) / Laundry Center
Frigidaire MLXE62RBW3 Frg(v2) / Laundry Center
Frigidaire MLXE62RBWD0 Kel(v10) / 27 " Electric Laundry Center
Frigidaire MLXE62RBWW0 Frg(v1) / 27 " Electric Laundry Center
Frigidaire MLXE62RED0 Frg(v1) / Laundry Center
Frigidaire MLXE62RED3 Frg(v1) / Laundry Center
Frigidaire MLXE62REW0 Frg(v2) / Laundry Center
Frigidaire MLXE62REW1 Frg(v0) / Laundry Center
Frigidaire MLXE62REW2 Frg(v0) / Laundry Center
Frigidaire MLXE62REW3 Frg(v2) / Laundry Center
Frigidaire MLXG42RBD0 Kel(v10) / 27 " Gas Laundry Center
Frigidaire MLXG42RBD1 Gib(v1) / 27 " Gas Laundry Center
Frigidaire MLXG42RBD2 Frg(v1) / Laundry Center
Frigidaire MLXG42RBD3 Frg(v1) / Laundry Center
Frigidaire MLXG42RBW0 Tap(v4) / 27 " Gas Laundry Center
Frigidaire MLXG42RBW1 Gib(v2) / 27 " Gas Laundry Center
Frigidaire MLXG42RBW2 Frg(v2) / Laundry Center
Frigidaire MLXG42RBW3 Frg(v2) / Laundry Center
Frigidaire MLXG42RBWD0 Kel(v10) / 27 " Gas Laundry Center
Frigidaire MLXG42RBWW0 Frg(v1) / 27 " Gas Laundry Center
Frigidaire MLXG42RED0 Frg(v1) / Laundry Center
Frigidaire MLXG42RED2 Frg(v1) / Laundry Center
  #2 (permalink)
Old 03-06-2012, 07:30 AM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
Quote:
HL,
You're sure the washer spins, slowly, or is it tumbling back and forth ? and the door locks and the spin enable switch on the door latch assembly is closed and sending the circuit up to the control board.
Do you have access to a multimeter
Part number: AP3873826
To check circuits, wires and voltage.
A place to start would be at the motor control board. Disconnect the JP4 connector(blue,red, yellow and two white wires) With a large needle or fine point awl, spread the metal contacts in the connector, and check for any frayed wires, and reattach the connector.
Remove the washer top trim panel, on each side of the tub assembly, you'll find a multi plug, basically disconnect the harnesses, check the wiring and makes siure the pins and female connectors are a tight fit when you reattach the connectors. Then check and see if the washer will spin.
Try this first, From there we'll need the multimeter and will need to access the washing machine control board, up inside the dryer cabinet in the right front corner, so we can check circuits and low voltage to the board.
Thanks,
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 03-31-2012, 02:49 PM
Junior Member
sandmon@me.com is on a distinguished road
Default
Hi I hope this post isnt too old to join..I have the exact same issue with the same machine EXCEPT My Model no. is MHW 2000 AWW I have been through the door switch and the selector dial ( The one that chooses the type of wash you want)I cleaned the terminals. Where can I find the control board? si it part of the motor control assembly?
Stephen
  #4 (permalink)
Old 04-02-2012, 07:18 AM
Senior Expert
Default
Quote:
Stephen
Stephen,
Your washer, machine control board,
Part number: AP4027830
Is located in the front, top right corner, of the dryer cabinet, you'll need to remove the dryer front panel and door assembly to access it.
As mentioned in the previous posts, you want to check as many components and circuits as possible, with a multimeter, especially the molex connectors mounted on the sides of the tub, before you go up to the control board(unless the door is not locking, Then start at the control board and check for a damaged, burnt R11 resistor).
Thanks and Good Luck,
__________________
Joe M. APP TEAM
  #5 (permalink)
Old 04-02-2012, 12:55 PM
Junior Member
Default Thanks
As it turns out, I had a bad connection on the lower tub displacement switch. Easy as pie an the first thing i cheched after the door/spin switches
Ill recommmend you to everyone!
Stephen
  #6 (permalink)
Old 04-02-2012, 01:20 PM
Senior Expert
Default
Stephen
Stephen, Great job.
We're glad for you, a nice easy check and repair.
Thanks for the update and the support.
Thanks Again,
__________________
Joe M. APP TEAM
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Washer/Dryer combo won't drain or spin uttdawg Washer Repair 5 12-30-2014 09:01 AM
LOW-SPIN DURING SPIN CYCLE of MayTag Neptune Dryer/Washer stack mrdhoffman Washer Repair 1 08-30-2011 06:45 PM
Spin problems Maytag Neptune Super Stack Gas Washer/Dryer Ellegator Washer Repair 2 03-25-2011 06:49 PM
maytag neptune washer will not spin gshurtz Washer Repair 6 03-25-2010 02:12 PM
Maytag Neptune washer does not spin chilisastry Washer Repair 1 03-19-2009 08:46 PM
