| » Mildewey smell from GE top loader |
Model Number: wjsr4160d5ww ser#mh912863g Brand: GE Age: 1 - 5 years
My GE top loader has a bad mildew smell for the last 2 months. I've tried vinegar, which was useless and bleach which helps temporarily. The tub definitely drains. I popped the front and disconnected the hose and checked the hose, pump and drain hose for blockages but found none. I can hear some water sloshing around from an apparently sealed section at the top of the tub. Should water be in there and could it be the source of the smell? I was thinking of drilling holes in the bottom of that section but thought it wise to consult with you experts first.
Thanks in advance for your help! TPTDC |
| Display Modes | |
| front loader will not final spin | gillpx | Washer Repair | 3 | 08-04-2008 06:44 AM |
| Front Loader Balance problem | bersie | Washer Repair | 2 | 12-18-2007 04:07 PM |
| front loader washer | Donald Belanger | Washer Repair | 4 | 12-07-2007 06:53 PM |
| front loader not draining | distress | Washer Repair | 1 | 09-14-2007 03:24 AM |
| Front loader not spinning correctly | Ferm2374 | Washer Repair | 0 | 08-10-2007 06:07 PM |
