i have a frigidaire front loader. when you turn it on , it sounds like its going to start and lock and unlock then turns off. replace the door lock and the electronic control board and i still have the same problem. can anybody help.
Originally Posted by: caleno i have a frigidaire front loader. when you turn it on , it sounds like its going to start and lock and unlock then turns off. replace the door lock and the electronic control board and i still have the same problem. can anybody help. I am having the same problem. I had E59 and E23 errors. I have replaced the Door Lock and Main Control boards. The E59 has went away, but the E23 is still there. I took out the drain pump and hooked it up to 120VAC @60Hz and it runs fine. I also hooked up a DMM to the input plug of the Drain Pump and it does not get the 120VAC needed to run during operation. This is a new control board, but I suppose it could be bad. Is there any other boards or parts that I could try? Thank you, Dave
Originally Posted by: lopesd I am having the same problem. I had E59 and E23 errors. I have replaced the Door Lock and Main Control boards. The E59 has went away, but the E23 is still there. I took out the drain pump and hooked it up to 120VAC @60Hz and it runs fine. I also hooked up a DMM to the input plug of the Drain Pump and it does not get the 120VAC needed to run during operation. This is a new control board, but I suppose it could be bad. Is there any other boards or parts that I could try?
Thank you, Dave I took back the new board and got a newer one. It fixed the problem. Thanks. Dave
