The water will not run in the maytag stack unit. The inlet valve was replaced however, the water still do not run in the machine.
Originally Posted by: doant The water will not run in the maytag stack unit. The inlet valve was replaced however, the water still do not run in the machine. The water will not run in the maytag stack unit. The inlet valve was replaced however, the water still do not run in the machine
i assume hot +cold valves are open
