Discuss
Washer wont agitate or spin
 in
Washer Repair
The washer fills with water then sits still while it goes through the wash cycle (without agitating) then it will
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer wont agitate or spin
  #1 (permalink)
Old 01-10-2008, 07:14 PM
chelli chelli is offline
Junior Member
chelli is on a distinguished road
Default Washer wont agitate or spin
Brand: Kitchen Aid   Age: 1 - 5 years
The washer fills with water then sits still while it goes through the wash cycle (without agitating) then it will drain and when it gets to the spin cycle it just sits there again. Could it be just a belt or something more expensive like a transmission? Help!!!
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-10-2008, 07:49 PM
Gene's Avatar
Gene Gene is online now
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Quote:
Does the motor run?
In order to provide the most accurate advise I need the complete model number of the washer.
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 01-11-2008, 01:45 PM
dexter dexter is offline
Junior Member
dexter is on a distinguished road
Default
Of course we'll need the model number to know for sure, but if it's a direct drive model it's probably just the coupler between the motor and transmission that needs replacing. It's an inexpensive part and you can usually tell if that is the problem by tipping the machine up and looking under it. There is usually a small pile of black rubber shavings on the floor under it as well. If you are somewhat handy this is not too difficult a part to replace yourself. As Gene said, the model number will help determine.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
washer will not spin or agitate nate Washer Repair 0 11-25-2007 12:44 PM
Washer will spin but not agitate dolpfan217805 Washer Repair 3 11-20-2007 11:44 AM
RCA Washer will not spin or agitate huffmanrq Washer Repair 0 11-18-2007 09:22 AM
washer won't spin or agitate chartman Washer Repair 0 11-12-2007 08:39 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
