owner
motor wont wash or spin, water in and pumps out ,checked motor 6 ohms on all 3 legs. need help thanks
The door lock assembly is the weak spot (well actually one of many weak spots) on this model.
Check it out, along with the wiring and use the tech notes under the top to check the main control unit and the motor control unit. |
| All times are GMT -7. The time now is 05:51 AM. |
