My Estate washer fills and agitates but won't advance to drain and spin. I drained it manualy by lowering the discharge hose but it won't spin in any cycle. I suppose it is the control/timer but wonder if could be other.
Most likely it is the lid switch. Check it out and replace it if it is bad.
Originally Posted by: sidfink43 Most likely it is the lid switch. Check it out and replace it if it is bad. :) Thanks!!! That was it
Great, glad you got it fixed and thanks for the update.
