Register | FAQ's | New Posts | Today's Posts | Extras |
» GE washer won't spin or agitate |
![]() Model Number: wpre6100gwt Brand: GE Age: 1 - 5 years
![]() My GE model #wpre6100gwt washer will not spin or agitate. The electric water pump works fine and produces a good stream of water out the drain pipe. Continuity is normal through the magnetic lid switch, and 121 volts is detectable from the switch to the motor. The motor, tub, and transmission turn freely. The motor is clean and shows no sign of excessive heat. Is there a relatively easy way to check the motor without damaging the circuit board on top of it? Related Models |
See inside of your appliance - diagrams and part photos for virtually every model.![]() powered by AppliancePartsPros.com |
![]() There are two things that most often cause this:
![]() I was able to get my washer working again by clearing the error codes. My problem was apparently caused by a power interruption.
To clear the error codes, turn the washer off. Disconnect power for about 20 seconds (pull the plug). Next, reconnect power and then open and close the lid five or more times within 12 seconds in the first 30 seconds of power-up. As crazy as this sounds, it should work if your model has the same electronics and if this is the only problem. If this fails to work or the problem is recurring, you may need on-site technical assistance to repair the problem. |
![]() Hi thanks anyways it's working now i guess we just didn't do the 1st reset right after sitting all night went back down & tried it again and yeah!!!!!! it works..seems like the lid switch cause it blinked 7 times thanks
![]() The light blinking 7 times means that the lid switch is stuck because the motor detected that the washer has been through the cycle 4 times and it hasn’t detected a lid opening. If the lid switch is bad the code will reoccur after 4 wash cycles. Sometimes these motors will flag an error for no reason so it may not come back and I wouldn’t worry about unless it does come back.
This page will show how to test the lid switch. http://www.appliance-repair-it.com/GE-washer-repair.html If the circuit fails to open with the lid up you need to replace the lid switch. |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
Kenmore Washer Won't Spin,Agitate,or Spin (Will Fill) | cowboys#1 | Washer Repair | 8 | 01-13-2011 10:13 AM |
Washer will agitate but not spin/spin slowly | sainthooligan | Washer Repair | 11 | 07-24-2010 10:34 AM |
Washer won't spin or agitate | aprilfarmer | Washer Repair | 1 | 12-09-2009 05:17 PM |
GE washer will not spin nor agitate | Evans | Washer Repair | 1 | 05-19-2009 06:01 PM |
washer won't spin or agitate | cindyahouser | Washer Repair | 0 | 04-20-2009 02:34 PM |
