we replaced the control panel it now fills up but will not kick into the next cycle seems to be a short water pump . any ideas?
Take off the water pump and clean out the drain system to make sure nothing is clogging it.
Then start the washer with the front cover off and see if the motor is turning.
Let us know what you find out. Good luck.
