Appliance Repair Forum
-   Washer Repair (http://forum.appliancepartspros.com/washer-repair/)
-   -   Maytag front load washer will not spin (http://forum.appliancepartspros.com/washer-repair/427313-maytag-front-load-washer-will-not-spin.html)
tmichael 02-27-2012 02:23 PM
13 month old maytag front load washer model # MHWE200XW00 is out of warranty. I have excellent water supply going into the unit. The unit seems to work at all functions except the drum will not spin. The unit shuts down after 6-7 minutes and displays an error code F7 and F1. The unit fills with water and then the drum starts to spin 1-2 very slow times and then stops the unit proceeds thruogh the cycle, rinse, drain, etc. and shuts down after 6-7 minutes. The drum will not spin, belt is good. Is this a water level pressure switch issue or could such a new unit have greater issues? Thanks, Mike.
tmichael 02-27-2012 02:50 PM
The unit will not agitate either.
thadrow 03-03-2012 04:27 PM
MAH4000AWW maytag neptune washer
door not locking and not spinning or extracting the water from the clothes..
hope it is not the circuit board...too expensive to fix.
Georgewbushus1 01-17-2013 03:06 AM
Maytag front loader door locks only and displays F21
