Discuss
Direct drive washer brake
 in
Washer Repair
anyone help regarding a direct drive machine ,I just replaced the drive block as it stopped spinning,it works fine now
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Direct drive washer brake
  #1 (permalink)
Old 08-01-2009, 03:27 AM
Junior Member
yurman is on a distinguished road
Default Direct drive washer brake
Model Number: 23662200   Brand: Kenmore   Age: 1 - 5 years
anyone help regarding a direct drive machine ,I just replaced the drive block as it stopped spinning,it works fine now but when it stops the brake comes on hard,would this have damaged the block through time and should i look at the brake now,
Related Models
Roper 2366W0A Ranges, Electric*
Jenn-Air 2370 SURFACE UNIT- DDRAFT ELE
Jenn-Air 2370EGS SURFACE UNIT- DDRAFT ELE
Roper 2374*0A Ranges, Electric*
Roper 2374*1A Ranges, Electric*
Roper 2374*2A Ranges, Electric*
Roper 2374W0A Ranges, Electric*
Roper 2374W1A Ranges, Electric*
Roper 2374W2A Ranges, Electric*
Jenn-Air 2375ERS SURFACE UNIT- DDRAFT ELE
Roper 2376*0A Ranges, Electric*
Roper 2376W0A Ranges, Electric*
Jenn-Air 2380EGS SURFACE UNIT- DDRAFT ELE
Roper 2382*2A Ranges, Electric*
Roper 2382W2A Ranges, Electric*
Roper 2384*0A Ranges, Electric*
Roper 2384*1A Ranges, Electric*
Roper 2384*2A Ranges, Electric*
Roper 2384*3A Ranges, Electric*
Roper 2384W0A Ranges, Electric*
Roper 2384W1A Ranges, Electric*
Roper 2384W2A Ranges, Electric*
Roper 2384W3A Ranges, Electric*
Jenn-Air 2385EGN SURFACE UNIT- DDRAFT ELE
Jenn-Air 2385EGS SURFACE UNIT- DDRAFT ELE
Jenn-Air 2390ERS SURFACE UNIT- DDRAFT ELE
Roper 2406*0A Ranges, Electric*
Roper 2406*1A Ranges, Electric*
Roper 2406*2A Ranges, Electric*
Roper 2406*3A Ranges, Electric*
Roper 2406W0A Ranges, Electric*
Roper 2406W1A Ranges, Electric*
Roper 2406W2A Ranges, Electric*
Roper 2406W3A Ranges, Electric*
Frigidaire 2408A GAS RANGE
Frigidaire 2408B GAS RANGE
Frigidaire 2408C GAS RANGE
Frigidaire 2409A GAS RANGE
Roper 2413*0A Ranges, Electric*
Roper 2413W0A Ranges, Electric*
Roper 2414*0A Ranges, Electric*
Roper 2414*1A Ranges, Electric*
Roper 2414*2A Ranges, Electric*
Roper 2414W0A Ranges, Electric*
Roper 2414W1A Ranges, Electric*
Roper 2414W2A Ranges, Electric*
Frigidaire 2418A GAS RANGE
Frigidaire 2418B GAS RANGE
Frigidaire 2420A GAS RANGE
Roper 2424*0A Ranges, Electric*
Roper 2424*1A Ranges, Electric*
Roper 2424W0A Ranges, Electric*
Roper 2426*0A Ranges, Electric*
Roper 2426*1A Ranges, Electric*
Roper 2426*2A Ranges, Electric*
Roper 2426W0A Ranges, Electric*
Roper 2426W1A Ranges, Electric*
Roper 2426W2A Ranges, Electric*
Frigidaire 2427A GAS RANGE
Roper 2428000 Ranges, Electric*
Frigidaire 2428A GAS RANGE
Frigidaire 2428B GAS RANGE
Roper 2438000 Ranges, Electric*
Frigidaire 2438A GAS RANGE
Frigidaire 2440A GAS RANGE
Frigidaire 2447A GAS RANGE
General Electric 24488L0 Electric range
General Electric 24488W0 Electric range
Frigidaire 2448A GAS RANGE
Frigidaire 2448B GAS RANGE
Frigidaire 2450A GAS RANGE
Frigidaire 2450C GAS RANGE
Frigidaire 2450E GAS RANGE
Roper 2453*9A Ranges, Electric*
Roper 2453*AA Ranges, Electric*
Roper 2453W0A Ranges, Electric*
Roper 2453W9A Ranges, Electric*
Roper 2453WAA Ranges, Electric*
Roper 2454X0A Ranges, Electric*
Roper 2454X1A Ranges, Electric*
Roper 2454X2A Ranges, Electric*
Roper 2454X3A Ranges, Electric*
Roper 2456X0A Ranges, Electric*
Roper 2456X1A Ranges, Electric*
Roper 2456X2A Ranges, Electric*
General Electric 24588B0 Electric range
General Electric 24588L0 Electric range
General Electric 24588W0 Electric range
Frigidaire 2458A GAS RANGE
Frigidaire 2467A GAS RANGE
General Electric 24688B0 Electric range
General Electric 24688L0 Electric range
General Electric 24688W0 Electric range
Frigidaire 2468A GAS RANGE
Amana 2474.000 MWAVE - FAMILY SIZE (60 HZ)
Jenn-Air 2475 SURFACE UNIT- DDRAFT ELE
Amana 2476.000 MWAVE - FAMILY SIZE (60 HZ)
Frigidaire 2477A GAS RANGE
Frigidaire 2478A GAS RANGE
Frigidaire 2478B GAS RANGE
Jenn-Air 2480 SURFACE UNIT- DDRAFT ELE
Jenn-Air 2485 SURFACE UNIT- ELE
Jenn-Air 24882 JENN-AIR REFRIGERATOR
Frigidaire 2488A GAS RANGE
Jenn-Air 2490 SURFACE UNIT- ELE
Roper 2492*0A Ranges, Electric*
Roper 2492*1A Ranges, Electric*
Amana 2492.000 MWAVE - FAMILY SIZE (60 HZ)
Roper 2492L0A Ranges, Electric*
Roper 2492L1A Ranges, Electric*
Roper 2492X0A Ranges, Electric*
Amana 2494.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 2494.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 2494.C MWAVE - FAMILY SIZE (60 HZ)
Amana 24940.A MWAVE - FAMILY SIZE (60 HZ)
Roper 2496*0 Ranges, Electric*
Roper 2496*0A Ranges, Electric*
Roper 2496*1 Ranges, Electric*
Roper 2496*1A Ranges, Electric*
Roper 2496*2 Ranges, Electric*
  #2 (permalink)
Old 08-02-2009, 04:35 AM
Senior Expert
APP Volunteer
richappy is a splendid one to behold
Default
You have bad brake shoes, a serious problem. Go to my "sticky" "replacing direct drive washer brake shoes" for info.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Replacing direct drive washer brake shoes richappy Washer Repair 38 12-21-2017 03:28 AM
direct drive washer cecil tillery Washer Repair 1 08-17-2009 06:35 PM
replacing drive coupleing on Whirlpool direct drive washer bbuck222 Washer Repair 2 08-06-2009 07:34 AM
Replacing direct drive washer brake shoes richappy Forum Announcements 0 02-28-2009 07:38 AM
Direct Drive Washer JNOLES Washer Repair 1 09-19-2007 04:24 PM
