Do it screw off or what,,,,Thanks
# 3 ,,,,{211130}
TUB BEARING LINER,,,,Thank you
It should slide off the transmission shaft. If there is prolonged exposure to water, and it is rusted, a little WD-40 and some coaxing will help it along. Then, before the replacement is installed, dressing of the shaft with emery is needed. The replacement should slide on without difficulty.
Thank you a lot, New parts should arrive Monday,,,,vmn
