Discuss
Washer Leaking while machine is turned off
 in
Washer Repair
New stainless hoses and new valve. Had to turn water off from valve to get it to stop leaking. Maybe
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer Leaking while machine is turned off
  #1 (permalink)
Old 02-24-2012, 09:38 PM
Junior Member
GloriaJean59 is on a distinguished road
Question Washer Leaking while machine is turned off
Brand: Maytag   Age: 5 - 10 years
New stainless hoses and new valve. Had to turn water off from valve to get it to stop leaking. Maybe hoses are not set right? Can the pump leak even if the washer is not running?? Just moved a month ago, did I break something?? It wasn't leaking before I moved it. I am reading so many posts, but nothing says machine leaks while not running. I know I have to take off the cover, just want to know which area I should be looking for, because this is not a huge leak. Model number is 11018202790.
  #2 (permalink)
Old 02-25-2012, 02:43 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Gloria,
In order to pinpoint the water leak you have to remove the washer cabinet first and, maybe, run the washer.
You have to observe: the pump which can leak even if the washer is not running, all hoses, the outer tub and the central seal.
You can watch how to remove the cabinet on the video. Also I attached the instructions to the reply.
Post the results of your inspection.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 03-01-2012, 04:32 AM
Junior Member
Thumbs up Found leak - Yeah!!!!!!
Thanks Gene for your reply, cabinet opened up with screws under the side covers. Turned on the valve and in three minutes noticed some water on the inlet valve. Every other hose and pump all dry. My son called it a solenoid, but it was listed as an water Inlet valve. So it is ordered and I already looked at the video on how to replace it. Will take two minutes. Thanks for all your help, now I really know how my machine works. Another VERY HAPPY customer...
  #4 (permalink)
Old 03-02-2012, 03:46 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You are welcome Gloria. Keep us posted on your repair.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Garbage disposal leaking at yhe boiiom when water is turned on dsloss1 Garbage Disposer Repair 1 11-13-2011 04:24 PM
water leaking around shaft that is turned by selenoid to drain dishwasher jrkohl Dishwasher Repair 0 10-26-2011 07:10 PM
leaking washer machine david.osborne Dishwasher Repair 0 04-22-2010 04:59 PM
Keep water turned off when not using washer? LintFilterGuy Washer Repair 1 07-27-2009 06:43 PM
Leaking after washer is turned on JohnMathapha Dishwasher Repair 3 01-16-2008 10:09 AM
