Discuss
ewesew
 in
Washer Repair
the washer will not spin, making a buzzing sound. took the motor off the motor coupler is not broken and
Appliance Repair Forum > Appliance Repair Help > Washer Repair » ewesew
  #1 (permalink)
Old 02-23-2012, 02:59 PM
Junior Member
ewesew is on a distinguished road
Default ewesew
Model Number: 11023032100   Brand: Kenmore   Age: 5 - 10 years
the washer will not spin, making a buzzing sound. took the motor off the motor coupler is not broken and doesn't seem to be worn. before it stopped spinning it made a loud noise . what can it be if it is not the motor coupler
Ads By Google
Related Models
Kenmore 11023032100 WASHER
Kenmore 11023032101 AUTOMATIC WASHER
Kenmore 11023032102 AUTOMATIC WASHER
Kenmore 11023034100 WASHER
Kenmore 11023034101 AUTOMATIC WASHER
Kenmore 11023034102 AUTOMATIC WASHER
Kenmore 11023036100 WASHER
Kenmore 11023036101 AUTOMATIC WASHER
Kenmore 11023036102 AUTOMATIC WASHER
Kenmore 11023652200 AUTOMATIC WASHER
Kenmore 11023662200 AUTOMATIC WASHER
Kenmore 11023692200 AUTOMATIC WASHER
Kenmore 11023712200 AUTOMATIC WASHER
Kenmore 11023722200 AUTOMATIC WASHER
Kenmore 11023732200 AUTOMATIC WASHER
Kenmore 11023812100 AUTOMATIC WASHER
Kenmore 11023822100 AUTOMATIC WASHER
Kenmore 11023832100 AUTOMATIC WASHER
Kenmore 11023902200 AUTOMATIC WASHER
Kenmore 11023902201 AUTOMATIC WASHER
Kenmore 11023904200 AUTOMATIC WASHER
Kenmore 11023904201 AUTOMATIC WASHER
Kenmore 11023912100 AUTOMATIC WASHER
Kenmore 11023912101 AUTOMATIC WASHER
Kenmore 11023912102 AUTOMATIC WASHER
Kenmore 11023922200 AUTOMATIC WASHER
Kenmore 11023922201 AUTOMATIC WASHER
Kenmore 11023924200 AUTOMATIC WASHER
Kenmore 11023924201 AUTOMATIC WASHER
Kenmore 11023932200 WASHER
Kenmore 11023934200 WASHER
Kenmore 11024082200 AUTOMATIC WASHER
Kenmore 11024084200 AUTOMATIC WASHER
Kenmore 11024086200 AUTOMATIC WASHER
Kenmore 11024422300 AUTOMATIC WASHER
Kenmore 11024432300 AUTOMATIC WASHER
Kenmore 11024442300 AUTOMATIC WASHER
Kenmore 11024622300 AUTOMATIC WASHER
Kenmore 11024632300 AUTOMATIC WASHER
Kenmore 11024642300 AUTOMATIC WASHER
Kenmore 11024652300 AUTOMATIC WASHER
Kenmore 11024692300 AUTOMATIC WASHER
Kenmore 11024812200 AUTOMATIC WASHER
Kenmore 11024812201 AUTOMATIC WASHER
Kenmore 11024822200 AUTOMATIC WASHER
Kenmore 11024822201 AUTOMATIC WASHER
Kenmore 11024832200 AUTOMATIC WASHER
Kenmore 11024832201 AUTOMATIC WASHER
Kenmore 11024892300 AUTOMATIC
Kenmore 11024894300 AUTOMATIC
Kenmore 11024902200 AUTOMATIC WASHER
Kenmore 11024902201 AUTOMATIC WASHER
Kenmore 11024904200 AUTOMATIC WASHER
Kenmore 11024904201 AUTOMATIC WASHER
Kenmore 11024922200 AUTOMATIC WASHER
Kenmore 11024922201 AUTOMATIC WASHER
Kenmore 11024924200 AUTOMATIC WASHER
Kenmore 11024924201 AUTOMATIC WASHER
Kenmore 11024932200 AUTOMATIC WASHER
Kenmore 11024932201 AUTOMATIC WASHER
Kenmore 11024934200 AUTOMATIC WASHER
Kenmore 11024934201 AUTOMATIC WASHER
Kenmore 11024942300 AUTOMATIC WASHER
Kenmore 11024944300 AUTOMATIC WASHER
Kenmore 11024946300 AUTOMATIC WASHER
Kenmore 11024952300 AUTOMATIC WASHER
Kenmore 11024954300 AUTOMATIC WASHER
Kenmore 11024956300 AUTOMATIC WASHER
Kenmore 11024962300 AUTOMATIC WASHER
Kenmore 11024964300 AUTOMATIC WASHER
Kenmore 11024966300 AUTOMATIC WASHER
Kenmore 11024972300 AUTOMATIC WASHER
Kenmore 11024974300 AUTOMATIC WASHER
Kenmore 11024982300 AUTOMATIC WASHER
Kenmore 11024992300 AUTOMATIC WASHER
Kenmore 11024994300 AUTOMATIC WASHER
Kenmore 11024996300 AUTOMATIC WASHER
Kenmore 11026292690 AUTOMATIC WASHER
Kenmore 11026292691 AUTOMATIC WASHER
Kenmore 11026292692 AUTOMATIC WASHER
Kenmore 11026292693 AUTOMATIC WASHER
Kenmore 11026292694 WASHER
Kenmore 11026292695 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11026294690 AUTOMATIC WASHER
Kenmore 11026294691 AUTOMATIC WASHER
Kenmore 11026294692 AUTOMATIC WASHER
Kenmore 11026294693 AUTOMATIC WASHER
Kenmore 11026294694 WASHER
Kenmore 11026294695 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11026702694 AUTOMATIC WASHER
Kenmore 11026722690 WASHER
Kenmore 11026801690 AUTOMATIC WASHER
Kenmore 11026812690 WASHER
Kenmore 11026814690 WASHER
Kenmore 11026822690 WASHER
Kenmore 11026824690 WASHER
Kenmore 11026824692 AUTOMATIC WASHER
Kenmore 11026832690 AUTOMATIC WASHER
Kenmore 11026832694 AUTOMATIC WASHER
Kenmore 11026834690 WASHER
Kenmore 11026834694 AUTOMATIC WASHER
Kenmore 11026842690 WASHER
Kenmore 11026842694 AUTOMATIC WASHER
Kenmore 11026844690 WASHER
Kenmore 11026844694 AUTOMATIC WASHER
Kenmore 11026892690 TB26-10- WARM RINSE
Kenmore 11026901690 SUPER CAPACITY PLUS AUTOMATIC WASHER
Kenmore 11026901692 AUTOMATIC WASHER
Kenmore 11026902692 AUTOMATIC WASHER
Kenmore 11026904692 AUTOMATIC WASHER
Kenmore 11026912690 AUTOMATIC WASHER
Kenmore 11026914690 WASHER
Kenmore 11026952691 AUTOMATIC WASHER
Kenmore 11027622790 AUTOMATIC WASHER
Kenmore 11027622791 AUTOMATIC WASHER
Sears 11027802691 AUTOMATIC WASHER
Sears 11027812690 AUTOMATIC WASHER
Sears 11027812691 AUTOMATIC WASHER
Sears 11027812692 AUTOMATIC WASHER
Kenmore 11027822790 AUTOMATIC WASHER
  #2 (permalink)
Old 02-23-2012, 05:08 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Did it agitate?
Did it drain?
Would the motor work on the spin cycle if it's removed from the washer?
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 02-23-2012, 05:21 PM
Junior Member
Default
it does agitate and drain , don't know how to check motor off the machine
  #4 (permalink)
Old 02-24-2012, 07:19 AM
Junior Member
Default checking the motor
how do you check to see if the washer will spin when not connected to the washer
  #5 (permalink)
Old 02-24-2012, 02:47 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by ewesew View Post
...it does agitate and drain...
It drains, then it pauses and should start to spin. Can you describe as much detail as possible what it does and does not.
__________________
  #6 (permalink)
Old 02-24-2012, 08:34 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Put the motor on the ground next to the washer with plug connected, make sure it is not touching anything, and then start the washer on spin cycle.
Make sure you use the jumper to bypass the lid switch.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
