Discuss
Frigidaire Washer Won't Stop Filling Up
 in
Washer Repair
Our washer recently stopped stopping. When I turn it on (no matter the load size, and even if it is
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Frigidaire Washer Won't Stop Filling Up
  By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 02-23-2012, 01:59 PM
Junior Member
hntpilcher is on a distinguished road
Default Frigidaire Washer Won't Stop Filling Up
Model Number: FWX233RES4   Brand: Frigidaire   Age: 5 - 10 years
Our washer recently stopped stopping. When I turn it on (no matter the load size, and even if it is empty) it will just fill up and fill up, and not stop. I can turn the dial to a spot where it will drain, and it drains just fine. But it won't move forward in the cycle on its own.
What could be causing this, and is it worth fixing?
Related Models
Frigidaire FWX233RES4 Frg(v0) / Washer
Frigidaire FWX233RES5 Frg(v0) / Washer
Frigidaire FWX233RES6 Frg/washer
Frigidaire FWX233RES7 Washer - Frigidaire
Frigidaire FWX233RET0 Frg(v0) / Free Standing Washer
Frigidaire FWX233RET1 Frg/washer
Frigidaire FWX414RGS0 Frg(v0) / Free Standing Washer
Frigidaire FWX414RGS1 Washer - Frigidaire
Frigidaire FWX433RBS0 Frg(v1) / 27 " Washer
Frigidaire FWX433RBS1 Frg(v1) / 27 " Washer
Frigidaire FWX433RBS2 Frg(v3) / Washer
Frigidaire FWX433RBS3 Frg(v1) / Washer
Frigidaire FWX433RBS4 Frg(v1) / Washer
Frigidaire FWX433RBS5 Frg(v1) / Washer
Frigidaire FWX433RBT0 Frg(v2) / 27 " Washer
Frigidaire FWX433RBT1 Frg(v2) / 27 " Washer
Frigidaire FWX433RBT2 Frg(v4) / Washer
Frigidaire FWX433RBT4 Frg(v2) / Washer
Frigidaire FWX433RBT5 Frg(v2) / Washer
Frigidaire FWX435RHS0 Frg(v0) / Washer
Frigidaire FWX435RHS1 Washer - Frigidaire
Frigidaire FWX435RHT0 Frg(v0) / Washer
Frigidaire FWX435RHT1 Washer - Frigidaire
Frigidaire FWX445LBS0 Frg(v1) / 27 " Washer
Frigidaire FWX445LBS1 Frg(v1) / 27 " Washer
Frigidaire FWX445LBS2 Frg(v1) / Washer
Frigidaire FWX445LBS3 Frg(v2) / Washer
Frigidaire FWX445LBS4 Frg(v0) / Washer
Frigidaire FWX445NBS0 Frg(v2) / 27 " Washer
Frigidaire FWX445NBS1 Frg(v2) / 27 " Washer
Frigidaire FWX445NBS2 Frg(v3) / Washer
Frigidaire FWX445NBS3 Frg(v2) / Washer
Frigidaire FWX445NBS4 Frg(v0) / Washer
Frigidaire FWX445RFS0 Frg(v1) / Washer
Frigidaire FWX445RFS1 Frg(v1) / Washer
Frigidaire FWX445RFS2 Frg(v1) / Washer
Frigidaire FWX445RFS3 Frg(v1) / Washer
Frigidaire FWX445RFS4 Frg(v1) / Free Standing Washer
Frigidaire FWX445RFS5 Washer - Frigidaire
Frigidaire FWX445RFT0 Frg(v2) / Washer
Frigidaire FWX445RFT1 Frg(v2) / Washer
Frigidaire FWX445RFT2 Frg(v2) / Washer
Frigidaire FWX445RFT3 Frg(v2) / Washer
Frigidaire FWX445RFT4 Frg(v2) / Free Standing Washer
Frigidaire FWX645DBD0 Frg(v2) / 27 " Washer
Frigidaire FWX645DBD1 Frg(v1) / 27 " Washer
Frigidaire FWX645DBW0 Frg(v1) / 27 " Washer
Frigidaire FWX645DBW1 Frg(v2) / 27 " Washer
Frigidaire FWX645GES0 Frg(v0) / Washer
Frigidaire FWX645GES1 Frg(v0) / Washer
Frigidaire FWX645LBS0 Frg(v1) / 27 " Washer
Frigidaire FWX645LBS1 Frg(v0) / 27 " Washer
Frigidaire FWX645LBS2 Frg(v4) / Washer
Frigidaire FWX645LBS3 Frg(v3) / Washer
Frigidaire FWX645LBS4 Frg(v1) / Washer
Frigidaire FWX645LBT2 Frg(v5) / Washer
Frigidaire FWX645LBT4 Frg(v2) / Washer
Frigidaire FWX645NBS0 Frg(v1) / 27 " Washer
Frigidaire FWX645NBS1 Frg(v1) / 27 " Washer
Frigidaire FWX645NBS2 Frg(v2) / Washer
Frigidaire FWX645NBS3 Frg(v0) / Washer
Frigidaire FWX645NBT0 Frg(v2) / 27 " Washer
Frigidaire FWX645NBT1 Frg(v2) / 27 " Washer
Frigidaire FWX645NBT2 Frg(v3) / Washer
Frigidaire FWX645RFS0 Frg(v0) / Washer
Frigidaire FWX645RFS1 Frg(v0) / Washer
Frigidaire FWX6968HW0 Frg(v0) / Washer
Frigidaire FWX6970E FRIGIDAIRE WASHER
Frigidaire FWX6970EW0 Frg(v0) / Washer
Frigidaire FWX6970EW1 Frg(v0) / Washer
Frigidaire FWX6970EW2 Frg(v0) / Washer
Frigidaire FWX6970EW3 Frg(v0) / Washer
Frigidaire FWX6970EW4 Frg/washer
Frigidaire FWX6970EW5 Frg(v0) / Washer
Frigidaire FWX6971E FRIGIDAIRE WASHER
Frigidaire FWX6971EW0 Frg(v0) / Washer
Frigidaire FWX6971EW1 Frg(v0) / Washer
Frigidaire FWX6971EW2 Frg(v0) / Washer
Frigidaire FWX6975E FRIGIDAIRE WASHER
Frigidaire FWX6975EW0 Frg(v0) / Washer
Frigidaire FWX6975EW1 Frg(v0) / Washer
Frigidaire FWX6975EW2 Frg(v0) / Washer
Frigidaire FWX833AS0 Washer - Frigidaire
Frigidaire FWX833AS1 Washer - Frigidaire
Frigidaire FWX833AS2 Frigidaire/washer
Frigidaire FWX833AS3 Frigidaire/washer
Frigidaire FWX833MAS0 Frigidaire/washer
Frigidaire FWX833SAQ0 Washer - Frig/gallery
Frigidaire FWX833SAS0 Washer - Frig/gallery
Frigidaire FWXB23RGS0 Frg(v0) / Washer
Frigidaire FWXB45RGS0 Washer - Frig/best Buy
Frigidaire FWXB45RGS1 Washer - Frig/best Buy
Frigidaire FWY833KAS0 Frigidaire/washer
Frigidaire FWY833KCS0 Frigidaire/washer
Frigidaire FXP18B4AW0 REFRIGERATOR
Frigidaire FXP18B4AW1 FRIGIDAIRE/REFRIGERATOR
Hardwick G-433 SURFACE UNIT- ELE
Hardwick G-436 SURFACE UNIT- ELE
Hardwick G-445 SURFACE UNIT- ELE
Jenn-Air G0206B-8 ELECTRIC GRILL OUTDOOR
Jenn-Air G100 SURFACE UNIT- DDRAFT ELE
Jenn-Air G101 SURFACE UNIT- DDRAFT ELE
Jenn-Air G102 SURFACE UNIT- DDRAFT ELE
Jenn-Air G103 SURFACE UNIT- DDRAFT ELE
Admiral G1110PRA RANGE- F/S STD GAS
Admiral G1110PRW RANGE- F/S STD GAS
Frigidaire G12W
Frigidaire G15W
Frigidaire G18W
Whirlpool G20EFSB2313 REFRIGERATOR
Whirlpool G20EFSB23S4 REFRIGERATOR
Whirlpool G20EFSB23S5 REFRIGERATOR
Whirlpool G20EFSB23S6 REFRIGERATOR
Whirlpool G20EFSB23S7 REFRIGERATOR
Whirlpool G20EFSB23S8 REFRIGERATOR
Whirlpool G20EFSB23S9 REFRIGERATOR
Frigidaire G21CL0 Frg(v1) / Gas Range
Frigidaire G21CW0 Frg(v2) / Gas Range
Frigidaire G21CW2 Frg(v1) / Gas Range
Frigidaire G21CW3 Frg(v2) / Gas Range
  #2 (permalink)
Old 02-23-2012, 04:56 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Open the control panel and check how good is the water pressure hose connected to the water level switch.
If the connection is good and the hose is not broken, replace the water level switch.
- The water level switch Part number: AP2105891
Here are the breakdown diagrams and Replacement parts for Frigidaire FWX233RES4 Frg(v0) / Washer | AppliancePartsPros.com
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE washer won't stop filling need of washer help2010 Washer Repair 5 06-16-2010 01:35 AM
Washer will not stop filling TOM901 Washer Repair 1 01-15-2010 10:58 AM
Frigidaire will not stop filling waldop1 Washer Repair 2 11-17-2008 07:55 AM
Frigidaire Washer Wont' Stop Filling aorose Washer Repair 2 05-28-2008 04:33 AM
washer won't stop filling mnestinger Washer Repair 1 11-14-2007 11:25 AM
