Discuss
Frigidaire front load - clanking noise
 in
Washer Repair
When the washer goes into the final spin, it shakes pretty bad and there is a clanking noise. Would this
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Frigidaire front load - clanking noise
  #1 (permalink)
Old 01-09-2008, 10:53 AM
champ649 champ649 is offline
Junior Member
champ649 is on a distinguished road
Default Frigidaire front load - clanking noise
Model Number: FWT449GFS0   Brand: Frigidaire   Age: 5 - 10 years
When the washer goes into the final spin, it shakes pretty bad and there is a clanking noise. Would this be coming from bearings or the motor? The machine is moved away from everything so it is not banging on anything.
No problems during regular spin, just the high speed final spin.
Thanks for the help.
S
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-10-2008, 11:29 AM
Junior Member
Default Simple question
Is there anyone out there that might know the answer to this problem?
Thanks.
  #3 (permalink)
Old 01-10-2008, 12:03 PM
bentwrench1999 bentwrench1999 is offline
Senior Expert
APP Volunteer
bentwrench1999 is on a distinguished road
Thumbs up Frigidaire front load - clanking noise
Remove the lower access panel and check out the little shock absorber. You will have one on each side of the tub. If these break, the machine makes a lot of noise. I sell a lot of these for some reason..Also make sure one of the suspension springs are not broken. The shock # is AP3856711.
Good Luck, wrench
__________________
  #4 (permalink)
Old 01-10-2008, 08:11 PM
Junior Member
Default
Thanks bentwrench1999:
The shocks and the springs are still in tack, no problems there. It just sounds like the motor is making the noise when it goes into the final high speed spin. Is there a transmission inside the motor that could have failed?
Thanks,
S
  #5 (permalink)
Old 01-12-2008, 03:08 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
If shocks and springs ok, you probably have a busted spin basket strut inside the tub, just get close to the tub and listen for the noise.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Frigidaire front load washer will not spin Merlis Washer Repair 6 01-05-2008 03:32 AM
Frigidaire Front Load New Door Lock kcchadmac Washer Repair 1 12-16-2007 07:38 PM
Dryer makes clanking noise Leonard07 Dryer Repair 2 12-05-2007 03:45 PM
Frigidaire Front Load Washer Won't Spin bbemis Washer Repair 2 11-28-2007 08:46 AM
spin cycle on frigidaire front load Mikki Washer Repair 2 10-08-2007 05:15 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
