| » White-Westinghouse won't rinse/spin |
Model Number: WWS833ES0 Brand: White-Westinghouse Age: 1 - 5 years
White-Westinghouse will fill and wash regardless of the settings. As soon as the timer approaches "rinse" the washer quits. For a few seconds after it stops the timer still makes noise, and will click twice, then stop. It will not drain. Manually moving the timer to rinse or spin and trying to start doesn't work either. I put a meter on the lid switch and it appears to be ok. Any help would be great.
Ads By Google Related Models Last edited by hotperro1 : 07-29-2009 at 08:21 PM. |
Hi Hotperro1
You need to be absolutely certain the problem is not the lid switch/lid lock, which you can do by by-passing it with jumper wires. If it turns out the lid lock/lid switch is ok, then I suggest replacing the timer. Here is the part Part number: AP2107583 Good luck
__________________
| Display Modes | |
| White Westinghouse Spacemate | dorothea | Washer Repair | 8 | 09-13-2009 09:06 PM |
| White Westinghouse Spacemate | dorothea | Washer Repair | 0 | 09-05-2009 12:44 PM |
| white westinghouse 2 speed | washing momma blues | Washer Repair | 1 | 12-15-2008 05:08 PM |
| Please Help.....White Westinghouse Spacemates | oceanmaid | Dryer Repair | 1 | 09-05-2008 04:16 PM |
| White Westinghouse washer won't spin | help_me_please | Washer Repair | 1 | 09-19-2007 04:29 AM |
