maclean
#1 Posted : Tuesday, July 28, 2009 11:08:42 AM(UTC)
maclean
Hi, my washer was running through the spin cycle and it began making a loud awful clunking noise which abruptly ended and when I went in to switch the clothes I found them sopping wet. I checked and it will not agitate or spin. Is this just a belt replacement, or something worse? help please!
sidfink43
#2 Posted : Wednesday, July 29, 2009 7:33:47 AM(UTC)
sidfink43
Hi Maclean
It is either a belt, motor or transmission.
Take off the front and you can tell if the belt is broken. If not run the machine with the front off. If the motor is turning, it is likely the transmission, which has tended to be a problem on Frigidaire top loaders.
Let us know what you find out.
Frigidaire Washer Won't Spin after replacing drive belt (Washer Repair)
by Shindigit 5/4/2013 10:54:15 AM(UTC)
frigidaire washer won't spin cloths dry (Washer Repair)
by MrVix 1/29/2012 12:17:20 PM(UTC)
Frigidaire Washer won't spin (Washer Repair)
by csnow 12/16/2011 8:06:42 AM(UTC)
by John Mascarena 12/12/2011 12:05:41 PM(UTC)
Frigidaire washer won't spin (Washer Repair)
by maggiemc 11/29/2011 6:39:13 PM(UTC)
Frigidaire Washer won't spin or drain (Washer Repair)
by jcutillo 8/21/2011 10:15:07 AM(UTC)
Frigidaire washer won't spin fast (Washer Repair)
by wiredmonkey 7/6/2011 9:35:37 AM(UTC)
Frigidaire washer won't spin won't drain (Washer Repair)
by janterry 2/16/2011 6:34:44 AM(UTC)
frigidaire washer won't spin out!! (Washer Repair)
by highwaystar 1/27/2010 7:56:47 PM(UTC)
Frigidaire Washer Won't Spin Out (Washer Repair)
by noley99 11/22/2009 7:13:08 AM(UTC)
by stein1960 11/21/2009 12:44:53 PM(UTC)
Stackable Kenmore/Frigidaire washer won't spin (Washer Repair)
by sidevinder 5/4/2009 9:48:51 AM(UTC)
by texican 3/5/2009 5:43:41 AM(UTC)
by jwes 11/29/2008 4:55:58 AM(UTC)
by cdiscolo 12/25/2007 6:39:58 AM(UTC)
